1 páginas (5 elementos)
equation solve problem - Mensajes
i want to solve below problem
m, ka, pa
i try to solve this problem
but i can't get result.
20230614_lateral earth pressure.sm (100,47 KiB) descargado 1420 vez(es).
Thanks in advance
m, ka, pa
Thanks in advance
Hi. Maybe the attached helps, but's hard to know. At the eqn 16 I count two open [ and only one closed ].
20230614_lateral earth pressure.sm (74,8 KiB) descargado 1433 vez(es).
My suggested solution is in the attached.
LateralEarthPressure.sm (9,05 KiB) descargado 1349 vez(es).
WroteMy suggested solution is in the attached.
Get more accurate solutions from roots(,,,)
LateralEarthPressure.sm (13,13 KiB) descargado 1383 vez(es).
Hi. Another way, plugin-less version. Have the advantage that can recognize the active and passive cases.
20230614_lateral earth pressure polyroots.sm (77,28 KiB) descargado 1381 vez(es).
