Numeric up-down Region
Numeric up-down Region - Adds a numeric up-down control - Mensajes
#1 Publicado: 6/2/2014 14:29:04
Grupo: Moderator
SMath Studio compatibility SMath Viewer compatibility mono compatibility
extension page Sources MIT license
Numeric Up-Down Control.
  • requirements: SS 0.96.5146 or later;
  • installation: SMath Studio: Tools > Plugins... > Online Gallery;
  • documentation: Numeric up-down Region.sm (28,81 KiB) descargado 1669 vez(es).;
  • languages: English;
  • main features:
    - Allowed inputs: region up/down buttons, + and - keys, mouse wheel; hold the input to have more increments.
    - Settings: double-click over the region.
    - Output: place a variable in the region placeholder.
    - Size driven by the value (manual resize not allowed).
    - Adds the same control in SMath Viewer.
>>> PLEASE REPORT IN THIS TOPIC ANY ISSUE, MORE DETAILED AS POSSIBLE <<<
Mostrar spoiler
Control Regions: CheckBoxList | ComboBoxList | ConditionallyFormattedLabel |  NumericUpDown | PathPicker | RadioButtonList | Slider
A 5 usuarios les gustó este mensaje
Вячеслав Мезенцев 7/2/2014 3:57:00, sergio 7/2/2014 5:06:00, IVR 7/2/2014 16:00:00, Radovan Omorjan 7/2/2014 2:19:00, ioan92 9/3/2014 13:22:00
#2 Publicado: 17/3/2014 19:02:55
Grupo: Moderator
UPDATED
(SMath Studio 0.97.5189)
- code updated to fit the new APIs features;
- hidden the outer frame (still remains as transparent to avoid interferences with resize markers).
#3 Publicado: 18/3/2014 19:18:44
Grupo: Moderator
Davide, it seems that description strings of the region are ignored in the viewer. Can that be changed or do I need to use sort of "nice" variable names?
Notenschlüssel.sm (11,53 KiB) descargado 109 vez(es).
#4 Publicado: 18/3/2014 19:48:19
Grupo: Moderator
I'll do it Martin... previously I've noticed a bug, now seems that the description text it works
#5 Publicado: 22/3/2014 13:44:41
Grupo: Moderator
UPDATED
- SMath Viewer: uses the region description (if exist and is shown).
ioan92 22/3/2014 13:59:00
#6 Publicado: 22/7/2014 4:56:30
127 me gusta en 342 mensajes.
Hello Davide,
It seems that the numeric up-down region remains active even when control is not checked
[albumimg]356[/albumimg]
After using the mouse wheel
[albumimg]357[/albumimg]
win7
smath 0.97 build 5301
Davide Carpi 22/7/2014 6:37:00
#7 Publicado: 22/7/2014 5:48:40
Grupo: Moderator
Grazie Sergio
Fixed, PLUGIN UPDATED
sergio 22/7/2014 9:48:00
#8 Publicado: 8/10/2015 10:36:19
Grupo: Moderator
I think it is possible...
Something like in the attachment? The entry point for the variable would be the form (like in table region) or in the context menu (like in the modeller region); this should grant customizable settings for every region, when you have multiple regions.
ioan92 8/10/2015 10:58:00
#9 Publicado: 28/10/2015 11:55:55
Grupo: Moderator
PLUGIN UPDATED SMath Studio 0.97.5737
- Introduced settings from canvas (see attachment);
- History Undo/Redo now is supported;
canvas settings.sm (17,29 KiB) descargado 1725 vez(es).
A 4 usuarios les gustó este mensaje
Andrey Ivashov 28/10/2015 16:35:00, ioan92 28/10/2015 12:15:00, NDTM Amarasekera 28/10/2015 12:40:00, sergio 28/10/2015 13:49:00
#10 Publicado: 22/9/2021 10:44:14
Grupo: Moderator
Not a bug but a cosmetic issue.
In Linux, plugin shows two square on each side of the value.
They are not written to variable, fortunately.
Davide Carpi 22/9/2021 14:43:00
#11 Publicado: 22/9/2021 14:47:54
Grupo: Moderator
Thank you, it appears because the thin space character is not available in that font (the irony... was added for cosmetic reasons too... )
I'll get rid of it for a more robust alternative.
#12 Publicado: 4/10/2021 7:48:47
Grupo: Moderator
PLUGIN UPDATED SMath Studio 0.99.7822 and later
  • buttons are now made by vector drawing;
  • removed thin spaces because issues in mono fonts;
sergio 4/10/2021 10:00:00
#13 Publicado: 25/10/2021 14:12:35
Renzo Choque
Renzo Choque
6 me gusta en 18 mensajes.
Hi, it seems that the "canvas setting" field does not recognize the "whatever" variable. I'm using smath in windows 10.Slider.png
#14 Publicado: 25/10/2021 21:18:43
Grupo: Moderator
I think this can be a bug.
When a setting has a string value, it can not be read by canvas settings.
Delete the "TickPosition" = "both" and whatever will be readable again.
I have tried this with "orientation" = "vertical", whatever can't be read by canvas settings.
Deleted the "orientation" = "vertical" element, and it can be available again.
This behavior made me to think there is something wrong while reading strings.
#15 Publicado: 26/10/2021 5:58:20
Grupo: Moderator
Thank you, confirmed. I'll fix it ASAP.
You are right, it is related to strings encoding. If you remove the space character from "maximum value" it works as expected.
#16 Publicado: 1/11/2021 6:44:42
Grupo: Moderator
Issue fixed in both NumericUpDown and Slider regions for latest SS stable and later.
#17 Publicado: 1/11/2021 13:56:08
Grupo: Moderator
String issue not fixed, at least for linux.
slider_options.sm (4,55 KiB) descargado 1582 vez(es).
#18 Publicado: 2/11/2021 5:58:47
Grupo: Moderator
Thank you, I can reproduce with your file even in windows... this issue it's something more subtle, though
#19 Publicado: 2/11/2021 11:56:10
Grupo: Moderator
Found it. You forgot to set the optimization to "none" on definitions, as indicated in the documentation. If you hover over the definition you can see that in both numeric and symbolic optimization the boolean equal between strings is preprocessed and stored as 0.
#20 Publicado: 2/11/2021 14:28:13
Grupo: Moderator
Thanks, now it works.
To be honest I didn't read the documentation in first post.
I only looked in Reference Book and couldn't see that information in it.
