Problem with summation
Problem with summation - Mensajes
#1 Publicado: 9/1/2011 12:30:22
Edward Ulle
Edward Ulle
21 me gusta en 182 mensajes.
Grupo: Moderator
I'm having a problem with summation.
I am comparing the area calculation with a known solution. First I use sum. The result is incorrect.
So I check it using a different method. Result is correct.
Check against an Excel solution. Result is correct.
Am I misinterpreting the sum function?
https://smath.com/wiki/GetFile.aspx?File=forum_attach%2fTheWizEd%2fsectionprop.zip
Ed
#2 Publicado: 10/1/2011 6:35:51
Grupo: Moderator
Hello Ed,
I think there is a bug in the summation operator.
[LIVE width=445 height=214]http://smath.info/live/?file=2123[/LIVE]
These two results should be the same, but they are not. I can not figure out how the summation operator get that number?
Here is another example - I am also puzzled here???
[MATH=eng]t←mat(2,5,1,2,2,2)[/MATH]
[MATH=eng]el(t,1,1)*el(t,2,2)-el(t,2,1)*el(t,1,2)=-1[/MATH]
[MATH=eng]sum((el(t,1,1)*el(t,2,2)-el(t,2,1)*el(t,1,2)),n,1,1)=3[/MATH]
Edward Ulle 10/1/2011 16:03:00
#3 Publicado: 10/1/2011 16:04:59
Edward Ulle
Edward Ulle
Grupo: Moderator
Radovan,
Thanks for the help.
I can get around it by a user function for now.
Ed
Ed
