Program for Linear and Polynomial Fit
Program for Linear and Polynomial Fit - Mensajes
#21 Publicado: 11/12/2019 13:31:21
Martin_B
Martin_B
22 me gusta en 84 mensajes.
Hope this document will tranquilize visitors/users !
Jean.
If that's what you think.
#22 Publicado: 11/12/2019 19:05:16
Does it work for you ... SS 7251 users please confirm ?
#23 Publicado: 11/12/2019 21:25:41
CBG
CBG
78 me gusta en 312 mensajes.
Hello Jean
Yes, It works
Carlos
#24 Publicado: 12/12/2019 0:09:00
NDTM Amarasekera
NDTM Amarasekera
130 me gusta en 352 mensajes.
Originally Posted by: MarB [url=/forum/yaf_postsm60156_Program-for-Linear-and-Polynomial-Fit.aspx#post60156][/url]If that's what you think.
It works. Thank you MarB.
#25 Publicado: 12/12/2019 7:41:20
NDTM Amarasekera
NDTM Amarasekera
That's my solution
- to separate the functions from matrix building,
- to use vectorize for speed
Apparently, the function f(#x):=1 if n=0 has a problem?. Or is it redundant?
For values n>0, the "otherwise" condition yields correct results irrespective of values in "if" condition.
Please check.
#26 Publicado: 12/12/2019 7:53:51
Martin_B
Martin_B
just put the 1 into a 1x1 matrix. That's all.
(And if you want to use units with the X Vector, just remove the eval and evaluate symbolically.)
That's my solution
Please check.
#27 Publicado: 12/12/2019 10:21:08
NDTM Amarasekera
NDTM Amarasekera
Hi
Still the same error when n=0.
Better if you can post the SM file please.
#28 Publicado: 12/12/2019 11:21:42
Martin_B
Martin_B
Sorry, I didn't realize, that vectorize behaves unexpectedly (to me), when the function does not include 'x'.
So I changed f to f(x):=[1+0*x] and now it works. The file is attached.
PolyFit.sm (11,92 KiB) descargado 1268 vez(es).
I would expect the results of g and h to be the same, and to be a 3 items long vector.
sergio 12/12/2019 16:13:00
#29 Publicado: 12/12/2019 11:49:54
NDTM Amarasekera
NDTM Amarasekera
Hi
Now I get same results as yours.
But the result (19.0833) of the Polyfit() function when n=0 ----> Does it have any meaning?
I have no idea. I was only testing it for all possible conditions..
Cheers MarB.
Note: Incidentally, 19.0833 happens to be the Mean of Y vector.
#30 Publicado: 12/12/2019 13:06:39
IMHO ... no need to complicate matters.
Modular design is easier to fix.
More automated is OK if you intend to poly for the entire Planet.
PolyFit (2).sm (46,79 KiB) descargado 1292 vez(es).
#31 Publicado: 12/12/2019 15:12:19
Hi. This is in case you want to interpolate with an horizontal line.
PolyFit.sm (159,33 KiB) descargado 1313 vez(es).
PolyFit.pdf (748,27 KiB) descargado 815 vez(es).
sergio 12/12/2019 16:12:00
#32 Publicado: 12/12/2019 15:15:52
NDTM Amarasekera
NDTM Amarasekera
Thank you, Alvaro.
