Loop Not Returning All Values
Loop Not Returning All Values - Programming - Mensajes
#1 Publicado: 27/1/2021 16:23:36
Tow Wai Lim
Tow Wai Lim
0 me gusta en 42 mensajes.
I've have a loop interpolating and searching for values. I not sure what went wrong, the loop is suppose to return 4 answer, however I am only getting (1), the last value.
Appreaciate some help and guidane.
Page7.sm (45,9 KiB) descargado 1393 vez(es).
#2 Publicado: 27/1/2021 20:27:26
Sorry Collab, I don't understand what you are interpolating.
That sub-spaces technique is very useful in many applications.
Page7 Subspaces.sm (41,92 KiB) descargado 1374 vez(es).
Tow Wai Lim 28/1/2021 10:50:00
#3 Publicado: 27/1/2021 21:48:48
Grupo: Moderator
Below you can find corrected file.
I have revised some equations in var_file() and G().
They were trying to reach out of matrix.
Since I don't have original mathcad file this is best I can do.
I did some error check but maybe you have to dig further.
Archivo no encontrado.
#4 Publicado: 28/1/2021 7:54:46
Tow Wai Lim
Tow Wai Lim
Hi Overlord,
Thanks for the reply. Although the val_file() is not returning the same answer as per the attached MathCAD but the overall loop actual works.
See attached calculation in mathcad.
Page 7.xmcd (97,02 KiB) descargado 1495 vez(es).
#5 Publicado: 28/1/2021 9:23:25
Hi Overlord,
Hi. val_find() returns the vector index, so it must to be the mathcad answer plus one, because ORIGIN:=0 in mathcad.
val_find.sm (134,2 KiB) descargado 1234 vez(es).
#6 Publicado: 28/1/2021 9:45:12
Page19 Search_Locate.sm (369,34 KiB) descargado 1168 vez(es).
#7 Publicado: 28/1/2021 10:48:40
Tow Wai Lim
Tow Wai Lim
Thanks Alvaro for your comment.
Jean, that is cool stuff... you can draw something like this in the SMath...
#8 Publicado: 28/1/2021 10:54:19
Grupo: Moderator
Hi Overlord,
Having the mathcad file revealed the difference of two programs.
The problem is n_min and n_max in smath version.
Mathcad assigns them [0 0], [0 1] and [1 1] only, whatever you enter.
min_offset and max_offset can be calculated within bounds of 9x9 matrix by them.
By that, offsets are always lower then 9 during max_offset=ii*n_max+1.
Your current smath function will produce out of matrix.
Because n_min and n_max are [1 1], [1 2] and [2 2].
And by adding ii to them it will be bigger than 9.
Algorithm should be revised with respect to that.
n_min and n_max should be lowered by 1 to correct it.
You can find re-revised file according to this.
If anything is unusual you can tell, we will try to fix it.
Page7_re-revised.sm (47,13 KiB) descargado 1375 vez(es).
Tow Wai Lim 28/1/2021 13:09:00
#9 Publicado: 28/1/2021 13:09:44
Tow Wai Lim
Tow Wai Lim
Hi Overloard,
Thanks for the comprehensive explaination. I will look into it and let you know if there are any bug.
#10 Publicado: 28/1/2021 14:30:02
Your project can be done entirely in Smath.
Unfortunately, it is not modular, unexplained
it reduces the de-bug sanity procedure.
