1 páginas (4 elementos)
Unified Soil Classification System USCS - spreadsheet - Mensajes
Attached is a spreadsheet to classify the soil according to USCS and the granulometric curve is plotted by sieving.
Please upload any improvements done to this file and post if any mistakes are found or if you have any suggestions.
This is the original code.
USCS1.sm (101,6 KiB) descargado 1848 vez(es).
This is the original code with another particle-size distribution
USCS.sm (103,17 KiB) descargado 2234 vez(es).
Below in another post it is updated with a better presentation of the granulometric curve.
WroteFit & explorer ... Jean
USCS fit Granulometry.sm (21,61 KiB) descargado 1772 vez(es).
Thank you so much,
I added the logistic sigmoid function you made to the initial code and it compare with and without the fit. In addition to the initial curve, I graphed it using the Zed Graph, where it can be better appreciated using a semilogx graph
USCS-fit-Granulometry.sm (175,97 KiB) descargado 1665 vez(es).
WroteThank you so much,
Thanks as well, very educative.
A large suite of math codes added
Project USCS fit Granulometry.sm (90,24 KiB) descargado 1772 vez(es).
