1 páginas (4 elementos)
Summation error - imaginary i as sum iterator - Changed summation behaviour? - Mensajes
Dear all,
Some years ago, I worked out a beam calculation tool in smath, based on singularity functions.
The sheet worked flawless in an older SMath version, but the most recent SMath-incarnations result in problems: the error seems to originate with the summation command.
How do I get this program working again?
I attach the original files: thanks for any feedback!
Kind regards from a Belgian SMath-fan,
Jan
Original file with summation error.sm (143,1 KiB) descargado 1345 vez(es).
Original file working.pdf (190,36 KiB) descargado 836 vez(es).
Jan
WroteHello.
This is because of using "i" as a variable.
Currently we have some issues regarding it.
Will be addressed soon.
Simple change to fix your worksheet:
Alternately: define the summations as local variable [SS 6179]
The document concludes the project.
Original file with summation error(1).sm (147,86 KiB) descargado 1291 vez(es).
janclaeys 19/3/2018 8:16:00
Thank you Andrei & Jean for the fast feedback!
