Plotting with 2D plot
Plotting with 2D plot - 2D Plot region not working? - Mensajes
#1 Publicado: 14/1/2021 10:36:02
Tommy Svartvatn
Tommy Svartvatn
0 me gusta en 6 mensajes.
Sample_1.PNGI can't get this to work properly. I have tested with just a simple function using x as variable, and it works. This will not!
#2 Publicado: 14/1/2021 12:12:16
Grupo: Moderator
You are trying to plot with units.
I don't think it is possible or maybe I am wrong.
I could plot without units by the way.
#3 Publicado: 14/1/2021 13:59:03
From the function you are trying to evaluate wrt scalar 'x',
give yourself two values of 'x', and their corresponding 'y' values
Then f(x):=linterp(X.Y,x) and plot f(x). linterp(,,,) ignores units
thus you have a clean plot free of units gyzmas.
#4 Publicado: 15/1/2021 7:45:28
Tommy Svartvatn
Tommy Svartvatn
Thanks, Jean.
Can you show me an example?
Best Regards, Tommy
#5 Publicado: 15/1/2021 10:48:47
... like this done 4 days ago.
In this one linterp(,,,) was just enough.
Eventually, you may have to collect more points for cinterp(,,,)
But check if cinterp(,,,) sterilizes units like linterp(,,,) ???
With cinterp(,,,) the "freak" factor may be more savant !
Does it work for your project ?
Integral (1) DoctoredRed (1).sm (37,69 KiB) descargado 1669 vez(es).
#6 Publicado: 20/1/2021 10:50:50
Tommy Svartvatn
Tommy Svartvatn
It seems Smath can do plotting with units, just not my function from above. However, I am missing functionality on the 2D plot settings, adjusting the x-axis, y-axis etc.
#7 Publicado: 20/1/2021 11:46:59
zoulou & Maya are pure decoration. Your unit system is not.
#8 Publicado: 22/1/2021 8:31:25
Tommy Svartvatn
Tommy Svartvatn
I'm not quite sure I get that...
#9 Publicado: 22/1/2021 10:47:07
For the QuickPlot @ X, Y are adjusted by mouse wheel.
Shift+mouse wheel => X
Cntrl+mouse wheel => Y
#10 Publicado: 25/1/2021 9:23:26
Tommy Svartvatn
Tommy Svartvatn
Can you tell me exactly what you mean by this? I have tried plotting with m (meters) inside the function, but in my original function, it is not possible to plot with units...
Tommy
#11 Publicado: 25/1/2021 10:12:34
Is that what you mean: plot with units labels ?
#12 Publicado: 25/1/2021 10:47:32
Tommy Svartvatn
Tommy Svartvatn
I am simply trying to plot the function with N/m as unit, since I was able to plot with m as unit, I don't understand what the issue is.
Nice formatting by the way...
#13 Publicado: 25/1/2021 11:30:46
Curiosity or bug ... Units adepts, can you doctor that one ?
#14 Publicado: 25/1/2021 21:22:15
Overlord has already published the correct answer about how to proceed to graph with units, but unfortunately I think that the user did not notice and was distracted by the other posts about ... I don't know about what they are.
#15 Publicado: 26/1/2021 4:17:15
fedeghi
fedeghi
25 me gusta en 112 mensajes.
Yes, first reply by Overlord has the answer
From a general point of view, you can plot functions with units:
  • by restoring "x" units in the input of the graph, since X-Y plot is going to place unitless scalars where "x" is.
    If your function expected an input with units, and since X-Y plot will feed that input without units, that's why you need to multiply "x" with that proper unit.
  • by dividing the complete function with the expected output unit of measure, since X-Y plot will only accept values without units on y-axis, while the original function to be plotted is going to generate results with units.
At least, that's how I depicted it in my mind to remember what to do.
Consistent units with different magnitude will consistently scale your "x" and "y" axis.
#16 Publicado: 26/1/2021 16:17:27
... while observing the SI conversion kJ/mol =>J/mol.
Adapt the remaining of the project to suit: tabulate/plot.
Integral 0000000 Transit-Units.sm (22,86 KiB) descargado 1614 vez(es).
#17 Publicado: 27/1/2021 11:52:07
hanskl
hanskl
7 me gusta en 158 mensajes.
Sorry for necromancing an old resolved post.
SMath is often able to plot with units, but you have to tell SMath the unit you are plotting along the x-axis (mm vs. cm vs. m), and you have to understand SMath plots the values along the y-axis in the SI units (that's the only way it knows how to).
In your case, you have to zoom far out on the y-axis to see the results.
What I usually do is what overlord did, dividing the function (within 2D plot) by the desired unit to force the results I want.
Best regards,
2D plot with units.sm (7,43 KiB) descargado 1658 vez(es).
