Solve with 4 args
Solve with 4 args - Is it a bug? - Mensajes
#1 Publicado: 15/7/2026 7:34:36
Valery Ochkov
Valery Ochkov
67 me gusta en 713 mensajes.
solve(4).sm (110,53 KiB) descargado 900 vez(es).
#2 Publicado: 15/7/2026 11:14:15
Hi Valery. It seems that solve doesn't know how to order the interval.
The 6 solutions numerically
And symbolically
solve(4).sm (158,3 KiB) descargado 915 vez(es).
#3 Publicado: 17/7/2026 7:17:36
Valery Ochkov
Valery Ochkov
Thanks, Alvaro
It is one task from the article
https://disk.yandex.ru/i/59sq-AYpKky-3Q
Editado 17/7/2026 7:28:06
#4 Publicado: 25/7/2026 5:40:05
Valery Ochkov
Valery Ochkov
Do you know the best solution in SMath?
#5 Publicado: 25/7/2026 15:50:39
Hi Valery. Two ways.
heart area.sm (13,36 KiB) descargado 865 vez(es).
Mathcad 11:
mc11 double int.mcd (4,77 KiB) descargado 877 vez(es).
Editado 25/7/2026 17:52:57
Valery Ochkov 25/7/2026 18:27:25
#6 Publicado: 25/7/2026 19:20:52
Valery Ochkov
Valery Ochkov
And what about this. We can create an animation.
Editado 25/7/2026 19:47:21
#7 Publicado: 26/7/2026 2:28:14
It's possible, although speed isn't one of SMath's main features. And with so few points, there isn't much accuracy.
heart area.sm (26,99 KiB) descargado 860 vez(es).
Valery Ochkov 26/7/2026 13:14:28
#8 Publicado: 26/7/2026 13:40:28
1.558 me gusta en 1.868 mensajes.
Grupo: Moderator
I can write a function that returns a set of closed isolines. The area can be calculated from the points on the curve. To construct implicit graphs, a function is used that returns the coordinate sets of the found isolines.
Valery Ochkov 26/7/2026 14:32:01, Alvaro 27/7/2026 1:20:46
#9 Publicado: 26/7/2026 14:36:05
Valery Ochkov
Valery Ochkov
Вячеслав, привет!
Брось все силы на создание инструментов оптимизации с ограничением типа Given... Minimize/Maximize в Mathcad 15. Этого очень не хватает в SMath.
И Андрей на это настроен.
#10 Publicado: 27/7/2026 1:25:09
Using Dragilev Method.
Area and Arc Length of an Implicit Planar Closed Curve - Dragilev Method.sm (16,28 KiB) descargado 879 vez(es).
Editado 27/7/2026 1:33:24
Valery Ochkov 27/7/2026 6:01:49, Вячеслав Мезенцев 27/7/2026 13:28:37
#11 Publicado: 27/7/2026 13:27:20
Grupo: Moderator
Yes, something like this with the Gaussian area formula.
ioan92 28/7/2026 11:13:51
#12 Publicado: 28/7/2026 8:24:46
Hi Viacheslav. In that case, I'd like to point out that dividing by the norme (Δ) means the curve is parameterized with respect to arc length, and that if you're going to improve the points using the original function, you must also do so with the parameter variable, which in the program's notation is T. This is because Dragilev's method ultimately obtains the parametric expressions x(t) and y(t) from the implicit function f(x,y) when starting from a point (xo,yo) on the curve.
This is one way to correct the arc length given by T if you choose to improve the curve points, although there must be better methods involving splines for curves in the plane, not just single-valued functions. There are also better approximations for the area enclosed by the curve; the one used here is simply the area defined by a closed polygon.
Area and Arc Length of an Implicit Planar Closed Curve - Dragilev Method.sm (17,78 KiB) descargado 360 vez(es).
Editado 28/7/2026 8:36:40
Valery Ochkov 28/7/2026 16:17:18
