Beta: SMath Studio 0.99.7666 (27 December 2020)
Beta: SMath Studio 0.99.7666 (27 December 2020) - Messages
#1 Posted: 12/27/2020 11:07:36 AM
2,318 likes in 4,001 posts.
Changes introduced in current build 0.99.7666
Improvements
  • Support to format content fragments added in Text Region (font size, font family, font weight; font style, text decoration, text color, background color, lines interval, paragraphs in Document mode);
  • Added possibility to restore automatic line breaks mode in Text Region by doubleclick on resizer.
Corrections
  • Critical error happened sometimes when using Del keyboard button in Math Region fixed.
Miscellaneous
  • Smart auto replacement functionality implemented for Text Region in Document Mode (f.e. inserting --- finalized by Enter will be replaced with horizontal rule; filling in equation in text will be detected as well);
  • Horizontal/vertical align toolbar buttons made hidden in Document mode;
  • Refactoring.
Download
SMathStudioDesktop.0_99_7666.Mono.tar.gz (1.43 MiB) downloaded 2073 time(s).
SMathStudioDesktop.0_99_7666.Setup.msi (2.31 MiB) downloaded 4636 time(s).
6 users liked this post
NDTM Amarasekera 12/27/2020 11:27:00 AM, IVR 12/27/2020 2:20:00 PM, Вячеслав Мезенцев 12/27/2020 5:50:00 PM, Martin Kraska 12/27/2020 6:55:00 PM, sergio 12/28/2020 10:20:00 AM, Igor Skarine 12/31/2020 8:03:00 PM
#2 Posted: 12/27/2020 6:54:30 PM
1,350 likes in 2,262 posts.
Impressive progress, Andrey.
I think the math detection is a bit over-greedy. As soon as I type a hyphen, the preceeding word is taken as a variable name and a math region is embedded. Thus the only way to add a hyphen between two words is to embrace it with spaces and delete the spaces afterwards. I'd recommend to do the conversion when Enter is pressed. A second enter then would leave the embedded math region.
IVR 12/28/2020 7:22:00 AM, Jason McCool 12/29/2020 11:21:00 AM, Andrey Ivashov 12/27/2020 8:17:00 PM
#3 Posted: 12/27/2020 8:32:39 PM
Thank you Martin very much for this suggestion!
I'm thinking about ways to make this detection more smart, more predictable to user and be easily cancelable (meaning it should be possible to cancel/undo it when it is done incorrectly or user wants to leave text as is). I have some thoughts about it, so yeah, this will be significantly improved.
Regards.
#4 Posted: 12/27/2020 8:40:43 PM
1,105 likes in 1,778 posts.
Hi. Thanks for the new features. BTW I can't paste in a math region with description, this is: if x:=line(something) I can't paste inside the x body if it have description.
paste.sm (3.79 KiB) downloaded 1405 time(s).
Andrey Ivashov 12/27/2020 9:09:00 PM
#5 Posted: 12/27/2020 9:09:11 PM
Hello Alvaro.
Thank you! Will fix it asap.
#6 Posted: 12/29/2020 11:30:25 AM
Jason McCool
Jason McCool
9 likes in 78 posts.
I'm getting an unhandled exception error when copying text regions by highlighting an existing text region and using the Control key + mouse to copy it. It does continue without crashing, and I can apparently copy by highlighting and using Ctrl-C and Ctrl-V, or by using the buttons on the menu bar. So far it only seems to be the Ctrl + mouse method of copying that used to work and doesn't in this build. Formulas still can be copied and pasted that way without error.
Thanks,
Jason
Andrey Ivashov 12/29/2020 4:18:00 PM
#7 Posted: 12/29/2020 4:19:33 PM
Thank you!
The reason of this error is the same as it is in the issue [USERLINK]Razonar[/USERLINK] mentioned above. Fixed now.
Jason McCool 12/29/2020 4:22:00 PM
