failing evaluation under vectorize()
failing evaluation under vectorize() - Messages
#1 Posted: 11/22/2023 1:22:45 AM
1,353 likes in 2,265 posts.
Why does the vectorize operation fail while it seems to be safe to use an explicit loop?
6-2-Bug.sm (27.78 KiB) downloaded 1394 time(s).
#2 Posted: 11/22/2023 2:41:12 AM
1,118 likes in 1,794 posts.
Hi Martin. Because you have just only one function which can't be vectorized: the norme or dot product of vectors.
sergio 11/22/2023 4:05:00 AM, Martin Kraska 11/22/2023 4:36:00 AM, ioan92 11/22/2023 4:58:00 AM
#3 Posted: 11/22/2023 4:35:34 AM
Is that just by observation or is there a fundamental obstacle?
#4 Posted: 11/22/2023 6:57:58 AM
Hi. I guess that it is fundamental.
Some notes about how other CAS handle this issue.
Pretty old matlab version, from its symbolic toolbox
The help page from the newest version
So, it looks like they have some issues with automatic vectorization.
With maple it is very uncomfortable, you need to use map even for simple cases
Wolfram's solution is very practical: Function with attribute 'Listable' expands over lists
But for make a table you actually need a loop or the Mathematica's Map function.
ioan92 11/23/2023 7:35:00 PM, Martin Kraska 11/25/2023 11:04:00 PM
#5 Posted: 11/25/2023 8:15:21 PM
Why does the vectorize operation fail while it seems to be safe to use an explicit loop ?
Set the demand in local definition mode ...
new(t):=|a(t)
vectorize and equate
6-2-Bug Doctored.sm (29.54 KiB) downloaded 1425 time(s).
#6 Posted: 11/25/2023 11:17:47 PM
Thanks Alvaro and Jean. Here is a reduced working example.
When a scalar function involves scalar products then it must be defined in a line()-block in order to be vectorize()able.
Worksheet13.sm (5.9 KiB) downloaded 1505 time(s).
Oscar Campo 11/26/2023 6:21:00 PM
