Problem with integral (again)
Problem with integral (again) - Definite Integral - Messages
#1 Posted: 12/15/2022 12:03:46 PM
Peter Pal Ther
Peter Pal Ther
0 likes in 3 posts.
Hi!
I have the following code, and the last integral is not solved by the program. I did not find any solution.
Can you explain me, what is the problem?
Thanks a lot!
Bye
Pali
HF.sm (72.86 KiB) downloaded 971 time(s).
#2 Posted: 12/15/2022 2:31:15 PM
Can you explain me, what is the problem ?
In some way doctored in red. Setup the integrator scalar wrt 'x'.
HF.sm (84.02 KiB) downloaded 965 time(s).
#3 Posted: 12/15/2022 3:01:55 PM
1,105 likes in 1,778 posts.
Hi Pali. At this time, you can't use if(..) inside an integral, use cases(...) instead. Also, SMath's integral new version can handle better units.
HF.sm (73.15 KiB) downloaded 968 time(s).
#4 Posted: 12/16/2022 6:41:10 AM
Peter Pal Ther
Peter Pal Ther
0 likes in 3 posts.
Hi Alvaro,
thanks a lot! It works fine. Thank you.
What do you mean: new version of integral?
Pali
#5 Posted: 12/16/2022 6:42:49 AM
Peter Pal Ther
Peter Pal Ther
0 likes in 3 posts.
I do not really understand what you did, but thanks for your help as well.
#6 Posted: 12/16/2022 9:37:18 AM
1. recast if/else ► if/otherwise.
2. made ∫ scalar wrt 'x' for local/vectorize
HFshort.sm (23.97 KiB) downloaded 925 time(s).
#7 Posted: 12/16/2022 2:49:11 PM
Hi Pali. In the "new" version of the integral it puts the units of the result correctly, while before some corrections had to be made. From "list of changes" here: Defined Integral supports units now.
Davide Carpi 12/16/2022 6:26:00 PM
