Bug in the SMAth by copy & paste of any varuable (CTR+C & CTR+V)
Bug in the SMAth by copy & paste of any varuable (CTR+C & CTR+V) - Messages
#1 Posted: 5/5/2021 7:57:12 AM
Andrey
Andrey
1 likes in 44 posts.
Dear SSMath Developer,
I think the SSMath version ( "0.99.7792" ) has a bug.
If one couples an object from the math. formula (with help of CTRL+C), then CTRL+V, then appears instead of the variable at the page a graphic
Best regards,
Andrey
#2 Posted: 5/5/2021 8:48:10 AM
1,435 likes in 2,914 posts.
This is because the plugin implements
public string[] SupportedClipboardFormats => new[] { DataFormats.UnicodeText };
Hence when a plain text is passed the plugin handle the action.
Guess would be needed a "paste as" when multiple plugins are available for such task, with the built-in as default (if any).
Andrey Ivashov 5/5/2021 6:57:00 PM
#3 Posted: 5/7/2021 9:46:10 AM
Andrey
Andrey
Hello Davide,
thank you for your answer.
Now I have the dilemma, which plugin is responsible for this effect...
I have to turn on and off each plugin step by step to determine it.
Best regards,
Andrey
#4 Posted: 5/7/2021 1:37:26 PM
Is the plugin that is shown when you paste the data
So in this case is XYPlotRegion probably
#5 Posted: 5/10/2021 5:28:30 PM
2,317 likes in 3,966 posts.
I've corrected plug-ins to disable handling of text from clipboard by default (as I see it was activated by mistake because of using the same code templates).
So issue is gone. One just need to update installed plug-ins. Note: the latest SMath Studio beta must be used.
#6 Posted: 5/11/2021 7:52:10 AM
Andrey
Andrey
Hello Andrey and Davide,
thank you for the help and the fixing of this nice tool.
Best regards,
Andrey
