Find and replace?
Find and replace? - Is this feature available in some plug-in? - Messages
#1 Posted: 10/12/2021 9:56:42 AM
fedeghi
fedeghi
25 likes in 112 posts.
Hi, is anybody aware of a method to find every occurrence of a "variable name" in a document, and replace it with another "new variable name" in every formula/occurence?
We have the built-in "find" (CTRL+F), but as far as I know it cannot replace also.
Does any plugin offer this feature?
Thanks
Bye
#2 Posted: 10/12/2021 10:18:54 AM
No, not as per you demand.
Utilities Matrix Find_Replace.sm (23.75 KiB) downloaded 907 time(s).
#3 Posted: 10/12/2021 2:25:51 PM
596 likes in 1,373 posts.
There is F8 key for replacing variable when you are inside of a function, line, etc.
But there is not a global search and replace as far as I know.
#4 Posted: 10/12/2021 2:56:27 PM
122 likes in 340 posts.
As a "sm" file is essentially an XML file, you can open it with an intelligent text editor (notepad ++) and do all the replacements with a special command
fedeghi 10/12/2021 3:54:00 PM
#5 Posted: 10/12/2021 3:56:31 PM
fedeghi
fedeghi
Thanks Overlord, I forgot to mention that I was referring to global "environment" instead of local variables inside a function
Thanks Sergio, I will give it a try, didn't think at this method
#6 Posted: 10/12/2021 4:11:30 PM
#7 Posted: 10/12/2021 4:14:15 PM
1,440 likes in 2,928 posts.
Text Region Utilities?
fedeghi 10/12/2021 4:45:00 PM, francesco rapuano 1/12/2025 5:40:00 PM
#8 Posted: 10/12/2021 4:44:38 PM
fedeghi
fedeghi
Super! As usual...
#9 Posted: 10/12/2021 5:39:35 PM
I wasn't using this on linux so totally forgot it.
While I was not using Search and Replace has been added.
It must be very long time since I had used it.
When I tried search&replace on linux there is that bug again.
Little blank squares are added front and end of variable.
Same cosmetic bug of Numeric UpDown Region.
But this time it effects variable names, not just cosmetic.
#10 Posted: 10/13/2021 4:21:57 AM
fedeghi
fedeghi
Davide, is there a way / syntax that allows "Text Region Utilities" plugin to substitute some text with a new text containing greek letters?
Example:
Thanks, bye
#11 Posted: 10/13/2021 7:41:58 AM
That's odd, nothing more than what you set as replacements should be added; I'll investigate it.
You can use regular expressions, like this:
The syntax means:
SEARCH anything that starts (^) with (S) and a subscript (\.) and capture anything after it ((.*)) [parethesis are the "capture" group, the period means "any character" and the asterisk "zero or more times"; BTW the subscript symbol is escaped with \ because otherwise it means "any character" )
REPLACE with sigma (σ) a subscript (.) and the first of the captured strings ($1)
This might be simplified or much more complicated depending on the cases (what is available on the worksheet and the patterns)
More on regular expressions: C# Regular Expressions
A nice tool to test patterns, with live preview: regex101.com
#12 Posted: 10/13/2021 9:09:56 AM
fedeghi
fedeghi
OK Davide, that's more or less the goal I had in mind, I'll need some more study about the proposed notation but you put me on the right path, thank you.
