Mathcad to SMath_function root and solve
Mathcad to SMath_function root and solve - Messages
#1 Posted: 3/26/2021 6:59:33 AM
matteo
matteo
0 likes in 5 posts.
can someone help me to copy this mathcad code in a SMath's one?
I have some problems with the solution of Xn
Thank you
#2 Posted: 3/26/2021 10:09:07 AM
matteo
matteo
0 likes in 5 posts.
ok,
thanks
verifica a flessione_prova.sm (43.07 KiB) downloaded 974 time(s).
#3 Posted: 3/26/2021 12:52:12 PM
1,084 likes in 1,760 posts.
Thank you
Hi. sigma.c fucntion is defined with an if clause. SMath can't integrate it, but you can use cases():
Now you can integrate:
#4 Posted: 3/30/2021 4:10:19 AM
matteo
matteo
0 likes in 5 posts.
Thanks Alvaro.
I made your correction, using the function cases(), but I have the same problem if I add other terms to fb(xn), for example if I add Ast*sigma sb(eps) and Asc*sigmasb(eps).
How is it possible?
Thanksverifica a flessione_prova2.sm (43.79 KiB) downloaded 895 time(s).
#5 Posted: 3/30/2021 6:37:01 AM
fedeghi
fedeghi
25 likes in 112 posts.
Possibly an odd bracket problem?
Here appears that Smath is making a group of "y+sigma bla bla" as object for the differential operator
So, fb(x) could not be evaluated.
I placed some brackets to clearly separate "y" from what follows in the equation, see picture below.
It appears that with brackets, fb(x) can be evaluated (but I get an error on units).
Maybe some other formula needs to be checked before?
Ciao!
#6 Posted: 3/30/2021 6:54:56 AM
fedeghi
fedeghi
Splitted the equation in three contributions, it appears the the integral is not consistent with other two terms of the sum
I think calculation should work, once you clear the unit issue which is hidden somewhere in other parts of the calculation.
Ciao
#7 Posted: 3/30/2021 8:03:34 AM
593 likes in 1,370 posts.
I am pretty sure my units mismatch correction is not suitable.
You should have to check this issue by yourself.
But I had managed to solve your function problem.
Rewriting it make function tick again.
verifica a flessione_prova2_rev.sm (45.02 KiB) downloaded 975 time(s).
#8 Posted: 4/3/2021 8:06:31 AM
1,438 likes in 2,924 posts.
I've had this pending in background so I'll share the solution even here. Aside the initial issues about if() and units, the integral fails when x_n is set as 0, since epsilon is something/0. Therefore solve range must exclude 0 or the function has to handle it.
Happy Easter and take care, anyone.
#9 Posted: 4/3/2021 6:45:13 PM
Thanks Davide ... Your's all too ... Jean
