SMath units
SMath units - Wrong units - Messages
#1 Posted: 11/24/2023 5:13:51 AM
Oichi
Oichi
4 likes in 35 posts.
For a simple harmonic oscillator with mass "m" (kg) and spring constant "k" (N/m), the angular frequency of oscillation is sqrt(k/m).
If we used the SI units, the angular frequency unit should be (rad/s) but when I use units in SMath it gives the answer in Hz..
So, is there a way that I can correct the units for an answer? Thanks in advance
#2 Posted: 11/24/2023 5:38:44 PM
Oscar Campo
Oscar Campo
135 likes in 309 posts.
You can change units in this way...
Oscar
Oichi 11/25/2023 12:36:00 AM
#3 Posted: 11/25/2023 12:13:01 AM
... Unit User Hz ... rad_s.sm (2.82 KiB) downloaded 999 time(s).
Oichi 11/25/2023 12:40:00 AM
#4 Posted: 11/25/2023 12:40:02 AM
Oichi
Oichi
Thank you all ^^
Oscar Campo 11/25/2023 3:57:00 AM
