problem with stack and reverse
problem with stack and reverse - Messages
#1 Posted: 5/20/2012 6:26:43 AM
1,438 likes in 2,923 posts.
This is a piece of a script to draw a IPE/HE beam cross section; the idea is to draw the section using the double symmetry of the profile, rather than do it point by point, but I've found some problems/incongruences... I think can be bugs, but I'm not sure...
stack reverse problems.zip
regards, w3b5urf3r
#2 Posted: 5/20/2012 6:57:10 AM
Hello w3b5urf3r,
I mentioned that in some other post reverse-and-interpolation
The problem could be resolved if you use Numerical optimization for the variables defined with reverse(). Just use it for your Q and S variables and everything will be fine.
Davide Carpi 5/20/2012 7:00:00 AM
#3 Posted: 5/20/2012 6:59:32 AM
Hello w3b5urf3r,
done, thank you!
P.S. this problem can't be resolved inside functions (see the end of updated stack reverse problems.zip)
Radovan Omorjan 5/20/2012 8:21:00 AM
#4 Posted: 5/20/2012 8:22:42 AM
Hello w3b5urf3r,
done, thank you!
Actually, it can. Inside your function use eval(reverse(...)) instead reverse(...).
