AlgLib 3.1x - AlgLib Plugin (based on ALGLIB 3.1x) - Messages
#41 Posted: 12/24/2018 7:47:08 AM
Updated.
alglib.ode.kinetic1.sm (7.78 KiB) downloaded 1526 time(s).
alglib.ode.kinetic2.sm (10.35 KiB) downloaded 1631 time(s).
alglib.ode.kinetic3.sm (10.04 KiB) downloaded 1641 time(s).
alglib.ode.test1.sm (10.46 KiB) downloaded 1609 time(s).
alglib.ode.test2.sm (10.63 KiB) downloaded 1583 time(s).
alglib.ode.Amplitude detector.sm (19.77 KiB) downloaded 1628 time(s).
alglib.ode.kinetic1.pdf (75.29 KiB) downloaded 907 time(s).
alglib.ode.kinetic2.pdf (89.97 KiB) downloaded 853 time(s).
alglib.ode.kinetic3.pdf (83.16 KiB) downloaded 833 time(s).
alglib.ode.test1.pdf (85.24 KiB) downloaded 838 time(s).
alglib.ode.test2.pdf (89.96 KiB) downloaded 859 time(s).
alglib.ode.Amplitude detector.pdf (147.84 KiB) downloaded 883 time(s).
5 users liked this post
bdrunagle 12/24/2018 8:15:00 AM, NDTM Amarasekera 12/24/2018 9:44:00 AM, sergio 12/24/2018 11:04:00 AM, frapuano 12/24/2018 2:22:00 PM, Radovan Omorjan 12/24/2018 2:52:00 PM
#42 Posted: 12/28/2018 2:02:54 PM
sergio 12/28/2018 4:14:00 PM, frapuano 12/28/2018 7:22:00 PM, NDTM Amarasekera 12/28/2018 10:53:00 PM
#43 Posted: 1/19/2019 4:31:14 PM
Updated. al_nleqsolve(2), al_nleqsolve(3), al_nleqsolve(4) added.
File not found. File not found. File not found.
#44 Posted: 1/27/2019 5:23:49 AM
With numeric optimization (for all functions) it works much faster.
Fourier series coefficients.sm (17.54 KiB) downloaded 1499 time(s).
Fourier series coefficients.pdf (138.41 KiB) downloaded 877 time(s).
4 users liked this post
Radovan Omorjan 1/27/2019 8:19:00 AM, Davide Carpi 1/27/2019 7:53:00 AM, frapuano 1/27/2019 8:21:00 AM, NDTM Amarasekera 1/27/2019 9:47:00 AM
#45 Posted: 1/27/2019 10:59:21 AM
Example 2.
Fourier series coefficients.sm (28.46 KiB) downloaded 1630 time(s).
Fourier series coefficients.pdf (170.26 KiB) downloaded 999 time(s).
sergio 1/27/2019 1:29:00 PM
#46 Posted: 1/27/2019 12:48:06 PM
Otherwise w/o Algib and more Engineering applications
Fourier Budapest39 Smoothing.sm (47.67 KiB) downloaded 1556 time(s).
#47 Posted: 1/27/2019 1:06:32 PM
Fourier-Fejer-Lanczos interesting too.
IrfanView "ResizeResample" zoom up/down in two options
Fourier or Lanczos the best.
Fourier Fejer Lanczos.sm (9.11 KiB) downloaded 1472 time(s).
#48 Posted: 2/18/2019 5:42:17 AM
Parameterization of implicit functions with al_nleqsolve
Parametrisation.sm (29.88 KiB) downloaded 1544 time(s).
NDTM Amarasekera 2/18/2019 11:46:00 AM, frapuano 2/18/2019 9:08:00 AM, Alvaro 2/18/2019 2:00:00 PM, Вячеслав Мезенцев 2/18/2019 5:50:00 PM
#49 Posted: 2/18/2019 1:59:33 PM
Hi Ber. Nice technique, easy to implement. You can also make that as a function, and monocolor too.
Parametrisation.sm (25.37 KiB) downloaded 1487 time(s).
Another option could be use y0 as vector, and solve for each element in y0, obtaining res, res1, ..., resn
Fridel Selitsky 2/18/2019 2:44:00 PM
#50 Posted: 2/18/2019 11:53:03 PM
1. SS 6179 does not complain
2. Takes ~ 1 hr to terminate the first function
3. NO plot result [NO complain but NO plot ?]
4. Would be interesting checking if the attached SS 6179
runs in your actual AlgLib 3.1x. If NOT => would be a dramatic bug.
It would indicate that all maths based al_nleqsolve would be scrap.
Contour SOLVE [Electron Solve algo Express].sm (20.66 KiB) downloaded 1286 time(s).
#51 Posted: 11/22/2020 4:47:54 AM
#52 Posted: 2/22/2021 4:06:56 PM
sergio 11/17/2021 12:20:00 PM
#53 Posted: 11/17/2021 11:42:24 AM
Fridel Selitsky 11/17/2021 12:18:00 PM, sergio 11/17/2021 12:20:00 PM, Alvaro 11/17/2021 1:00:00 PM, NDTM Amarasekera 11/17/2021 4:44:00 PM
#54 Posted: 12/8/2021 2:43:14 AM
#56 Posted: 12/20/2021 4:18:35 PM
Plugin updated.
Changes:
- solution restructured;
- converting the task for the ODE solver to the numerical form is now performed through the Mathcad Toolbox plugin (to avoid code duplication), so it must be installed;
- refactored.
Solvers that support mathematical notation now reuse code from the Mathcad Toolbox plugin. Now there is no need to recompile every such plugin.
