UPDATED: SMath Studio 0.98.6356 (27 May 2017) - Messages
Changes introduced in current build 0.98.6356
Improvements
- SS-2443: Function vectorize(...) now acts even on 1-element matrices;
- Application enabled to use .Net Framework 4.0 or higher if no .Net Framework 2.0/3.0/3.5 installed on client Windows PC;
- Multiple improvements done into Core to support personal user settings.
Corrections
- SS-2436: Boolean equality calculations: fixed strings vs different types;
- Incorrect program window location on start fixed;
- Critical issue fixed appeared in some cases when changing math equation display options using context menu;
- Settings Saving/Loading stability improved;
- Loading of language files corrected when not all of them are available.
Miscellaneous
- DEV: SessionProfile allows to store settings from plug-ins now;
- Interface translations updated;
- Refactoring.
Download
SMathStudioDesktop.0_98_6356.Mono.tar.gz (1.25 MiB) downloaded 2130 time(s).
SMathStudioDesktop.0_98_6356.Setup.msi (2.12 MiB) downloaded 5013 time(s).
The only visible change to the build released yesterday is:
- Usage of Descriptions for MathRegion (and other regions which contains MathRegion) are fixed - previously any input was duplicated between region equation and description.
Best regards, Andrey Ivashov.
In my megabyte heavy smath worksheets I was faced with very long recalculation times for the new build. I have "time stamped" the worksheet an realised that major chunk of reclaulation time is spent before any calcs are done in the worksheet.
This behavior is repeatable over many worksheets.
I will gladly share the worksheet privately via email.
Thanks!
WroteI will gladly share the worksheet privately via email.
Please send a worksheet to me, so I could test and fix this issue.
Thanks in advance!
