Smath changes the final unit arbitrarily not what I want
Smath changes the final unit arbitrarily not what I want - Messages
#1 Posted: 6/7/2016 5:58:34 AM
farzadtb
farzadtb
0 likes in 10 posts.
Hi All
having defined some parameters let's say with the unit of Mpa I noticed that the final results are given in Pa (Pascals) and I can not change it or I don't know how to change or preset to force Smath to give me the results in Mpa. Any ideas ?
#2 Posted: 6/7/2016 6:07:33 AM
Mike Kaganski
Mike Kaganski
184 likes in 434 posts.
It's not changing them "arbitrarily", it uses base SI units. There's no preset currently (except for currently unsupported direct-edit way to choose imperial units). But you may put cursor to the trailing placeholder in an expression and put the desired units there.
С уважением, Михаил Каганский
#3 Posted: 6/7/2016 6:29:08 AM
1,082 likes in 1,755 posts.
Hi farzad. Check
from minute 2"30.
#4 Posted: 6/7/2016 12:22:13 PM
The default unit is Pa. Divide your result MPa User.gif add user unit
#5 Posted: 6/7/2016 12:41:34 PM
1,438 likes in 2,920 posts.
https://smath.com/wiki/Units.ashx
Quote
Evaluating an expression that contain units, the output will be delivered with the default units (SI base units); to change the output unit, write your favorite unit in the right placeholder.
#6 Posted: 8/4/2016 10:45:59 PM
Bill Holliday
Bill Holliday
0 likes in 1 posts.
None of this works for me. I need to change 'Pa into 'kWh/'m^3 (energy density) but trying to insert my units into the trailing placeholder just produces a mess of other units. Sometimes the actual calculation gets messed up too!
Bill
#7 Posted: 8/5/2016 6:12:56 AM
Bill
Hello Bill,
this is because kWh doesn't exists in the built-in units; you have to use 'kW*'hr/'m^3 or define your own unit somewhere in the worksheet (see the attachment)
kWh (cloud)
Andrey Ivashov 8/5/2016 11:21:00 AM
