(SOLVED) HRESULT: 0x800700C1
(SOLVED) HRESULT: 0x800700C1 - mushoe - Messages
#1 Posted: 10/8/2013 7:11:01 PM
Mushoe
Mushoe
0 likes in 3 posts.
Please help! I am trying to do a simple natural log function and I keep getting the error " is not a valid Win32 application. (Exception from HRESULT: 0x800700C1)".
I am running v0.96 (build 4909) on Windows 7 x64.
#2 Posted: 10/9/2013 3:11:10 AM
uham1867
uham1867
0 likes in 2 posts.
hi mushoe
if you have installed one or more WIN 32 plugin delete it, then it should work
Greetings uham67
#3 Posted: 10/9/2013 5:19:11 AM
1,353 likes in 2,265 posts.
Do you use the unofficial portable distribution? If not, you might give it a try.
Edit: Link corrected
#4 Posted: 10/9/2013 5:41:53 AM
127 likes in 342 posts.
Hi Martin,
the link to the "unofficial portable version" does not work properly (Page not found)
Davide Carpi 10/9/2013 6:55:00 AM
#5 Posted: 10/9/2013 7:58:48 AM
kilele
kilele
134 likes in 397 posts.
This is the correct link
#6 Posted: 10/9/2013 10:03:10 AM
Mushoe
Mushoe
0 likes in 3 posts.
I tried removing all plugins from my install, but that did not work. I then tried the portable version and it solved my issue!
Thank you so very much!
I had defined r0 above, I just forgot to move it down when I took the screen shot.
Mushoe
#7 Posted: 10/9/2013 10:16:36 AM
1,442 likes in 2,935 posts.
Good
BTW I suggest you to follow the hint made by ioan92, sometimes something goes wrong with the installed version, a clean install can solve issues (tried myself this summer with an annoying red cross of death moving the vertical scrollbar)
regards,
Davide
#8 Posted: 11/27/2013 1:19:21 PM
Mushoe
Mushoe
0 likes in 3 posts.
Just a follow up. I have been using the unofficial portable version for a while now and it has been working as expected with no strange errors. Thanks again to all for the help!
https://smath.com/wiki/(S(iymz0v3hvaquj12ic1kr4yfo))/Default.aspx?Page=SMath%20with%20Plugins
