[Dev] How to convert Term[] to Entry
[Dev] How to convert Term[] to Entry - Messages
#1 Posted: 8/16/2017 4:51:38 AM
1,336 likes in 2,250 posts.
Hi, how can I convert a terms list to an entry structure? The core doc says there is a function SMath.Manager.TryFixStructure, which unfortunately doesn't seem to be available in 0.98.6398.
I also failed to find a function to convert expression strings to Entry.
Thanky you for any hint.
#2 Posted: 8/16/2017 5:21:07 AM
1,438 likes in 2,920 posts.
You can use the static method Entry.Create(IEnumerable value)
Entry myEntry = Entry.Crate(myTermsArray);
Martin Kraska 8/16/2017 7:14:00 AM
#3 Posted: 8/16/2017 7:26:33 AM
Thanks, Davide,
Seems that I asked the wrong question, I misunderstood an VS error message. It was about the result type, not of the argument type of Decision.NumericCalculation. I need to see how to handle TNumber objects.
BTW, if I want to move towards Entry instead of Term[] in the function arguments, do I need to do that everywhere at once or can I do that that step by step without breaking the whole plugin?
Martin
#4 Posted: 8/16/2017 3:06:36 PM
Numeric library makes really easy to handle TNumbers... some examples here (see f.e. fft2) and here (logic starts from line 360) (I'll look if I can post something compact and complete later tonight)
Absolutely, you can start implementing the IPluginLowLevelEvaluationFast instead of the IPluginLowLevelEvaluation, and convert Entry to Terms[] from where you don't are yet arrived in refactoring.
