Generating Control Valve Curve using SMATH
Generating Control Valve Curve using SMATH - Messages
#1 Posted: 4/22/2023 12:04:37 PM
usamakhan
usamakhan
3 likes in 79 posts.
I have Chinese valves where from nameplate I can get Cv @100% open & that its Equal%.
Now I generated a spreadsheet model which is fairly simple & then used 'Goal Seek' feature to iterate values such that I get stated Cv at 100% opening.
I am uploading procedure that I followed (this document also has a small video file)
I am also attaching spreadsheet file as well.
External server zip file: https://www.mediafire.com/file/8qhwt7riweby457/Characteristic+Curve+Generation.zip/file
Now how can I do this in SMATH Studio? I mean construct in such a way that I change one value such until I get required CV at 100% as well as each interval increment is equal percentage
Characteristic Curve Generation.zip (2.39 MiB) downloaded 358 time(s).
#2 Posted: 4/22/2023 9:06:30 PM
1,118 likes in 1,794 posts.
ValveCv.pdf (76.19 KiB) downloaded 734 time(s).
ValveCv.sm (13.89 KiB) downloaded 1143 time(s).
#3 Posted: 4/24/2023 9:21:14 AM
If your valve would be Fisher Controls, you should be able
to reach the catalog page c/w cv/% opening + more valve data.
This document fits = % & quick opening.
As a separate Smath document, I have the Fisher valve sizing procedure,
including the pulp stock.
Fisher.sm (34.21 KiB) downloaded 1183 time(s).
#4 Posted: 4/24/2023 2:06:51 PM
usamakhan
usamakhan
Extremely thanks Razonar & Jean
