SMath crashes when opening a project
SMath crashes when opening a project - the problem with the text region - Messages
#1 Posted: 11/27/2021 5:53:40 AM
Artem
Artem
0 likes in 1 posts.
1)If you add an empty text region to a text region and save the project, SMath freezes and crashes when you try to open it again.
At the same time, if you add a non-empty text area to the text area, the project will open after saving
2)If you add a text region to the test region and try to select both regions and change the font size of the text regions, SMath freezes and crashes
#2 Posted: 11/28/2021 7:15:40 AM
596 likes in 1,373 posts.
This is the error I corrected some users documents time to time.
It requires manually editing the smath file with a text editor.
