CoolProp Wrapper
CoolProp Wrapper - Pure and pseudo-pure fluid equations of state and transport properties for 122 components - Messages
#61 Posted: 4/21/2023 3:17:35 PM
1,550 likes in 1,863 posts.
How can I get properties of mixtures e.g
CoolProp_Props("Dmass","T",273+100,"P",101.3*10^3,"Helium[0.5]&Xenon[0.5]"
ref: http://www.coolprop.org/fluid_properties/Mixtures.html
This can't be done directly in the current version of the plugin. It is not clear how to call the apply_simple_mixing_rule() function from the library, it can't be imported as it is not in the export table.
Click to enlarge
Click to enlarge
maple-python-coolprop.sm (6.61 KiB) downloaded 1638 time(s).
maple-python-coolprop.pdf (19.18 KiB) downloaded 1140 time(s).
Click to enlarge
maple-python-coolprop-2.sm (5.08 KiB) downloaded 1605 time(s).
#62 Posted: 4/22/2023 5:00:09 AM
1,118 likes in 1,794 posts.
Hi. Notice that Refprop from NIST can't handle He/Xe mixing either. At least version 9.
On the other hand, maple doesn't seem to implement the procedure that Viacheslav points out either, as can be seen in the online documentation for the latest version.
However, very good values can be obtained using Coolprop in SMath and some basic stoichiometry.
Mixing gases.sm (19.17 KiB) downloaded 1568 time(s).
Mixing gases.pdf (67.22 KiB) downloaded 971 time(s).
#63 Posted: 4/22/2023 5:34:44 AM
More simple
Click to enlarge Click to enlarge Click to enlarge
maple-python-coolprop-3.sm (10.97 KiB) downloaded 1588 time(s).
maple-python-coolprop-3.1.sm (10.82 KiB) downloaded 1592 time(s).
maple-python-coolprop-3.2.sm (10.89 KiB) downloaded 1510 time(s).
Alvaro 4/22/2023 9:32:00 AM
#64 Posted: 4/27/2023 3:09:34 AM
Now you can write like this
maple-python-coolprop-3.3.sm (9.51 KiB) downloaded 1607 time(s).
#65 Posted: 4/28/2023 7:39:13 AM
Or like this
maple-python-coolprop-3.4.sm (10.66 KiB) downloaded 1604 time(s).
maple-python-coolprop-3.5.sm (10.3 KiB) downloaded 1581 time(s).
#66 Posted: 4/29/2023 3:33:10 PM
Click to enlarge
maple-python-coolprop-3.6.sm (9.98 KiB) downloaded 1572 time(s).
#67 Posted: 4/29/2023 10:07:03 PM
churichuro
churichuro
29 likes in 79 posts.
is fantastic!
this no work the first time but after I play with the another examples this work, very well
thank you!
#68 Posted: 5/4/2023 10:29:17 AM
Without "pyfile" (inline multiline script). The script should be without comments.
Space padding is necessary here so that inside the script, when a large string is divided into parts, the line break character itself is not divided ( '\n' -> '\ n' ).
maple-python-coolprop-3.7.sm (9.9 KiB) downloaded 1601 time(s).
maple-python-coolprop-3.8.sm (6.84 KiB) downloaded 1598 time(s).
maple-python-coolprop-3.9.sm (8 KiB) downloaded 1547 time(s).
#69 Posted: 7/30/2023 8:12:32 AM
usamakhan
usamakhan
3 likes in 79 posts.
Uni, can you please help me how to add python into SMATH, I have python already in system [WinPython 3.9] How I link it up with Smath?
I have working CoolProp
#70 Posted: 7/30/2023 1:33:42 PM
usamakhan
usamakhan
Jean, can you help me how do integrate python in my Smath? I event tried environmental variables under Win10 but didn't work
#71 Posted: 7/31/2023 3:45:32 AM
You should use a double slash for the full path.
In this case, you need to check whether python is available from the command line. If not, it means that the paths are specified incorrectly.
#72 Posted: 8/2/2023 7:17:11 PM
usamakhan
usamakhan
uni, thanks a lot
Can you tell me what is this block you used after python sub-section [i.e with the square bracket & holding script conetnts]
Additionally Razonar sample here is also very intuitive while calculating mixing values
https://en.smath.com/forum/yaf_postsm82120_Understanding-Redlich-Kwong-equation-of-state.aspx#post82120
#73 Posted: 8/3/2023 3:06:16 AM
uni, thanks a lot
Mathcad Block from the Mathcad Toolbox plugin and just Text inside it for the script.
#74 Posted: 8/4/2023 3:23:07 PM
usamakhan
usamakhan
uni, so it means the text inside the block is not automatically generated. Can you please explain the construct
On second note you were correct, I fixed my environment variable under windows %python% now works
#75 Posted: 8/8/2023 2:01:18 AM
Phase diagrams with CoolProps.
Click to enlarge
PhaseDiagram.sm (39.17 KiB) downloaded 1586 time(s).
Davide Carpi 8/8/2023 2:10:00 AM
#76 Posted: 8/9/2023 3:47:50 AM
Psychrometric Chart with CoolProps. 'Simplified' version (more readable): Enthalpy lines overlap web bulb temperature lines.
Click to enlarge
PsychrometricChart.sm (125.39 KiB) downloaded 1559 time(s).
#77 Posted: 8/21/2023 5:39:50 PM
usamakhan
usamakhan
I think I have found some problems while using plugin to get phase properties as discussed here: http://www.coolprop.org/coolprop/HighLevelAPI.html#imposing-the-phase-optional
First when using "P|phase_gas" it doesn't accept units & T,P values have to be directly written in SI equivalent
Second there is a value discrepancy when using "P" & "P|phase_gas" for a fluid that exists only in gas phase at that T,P
#78 Posted: 4/16/2024 3:55:20 AM
1,353 likes in 2,265 posts.
It seems that multiple instances of SMath can't use the plugin at the same time.
How to reproduce:
1. Open SMath and access any Coolprop function
2. Open another SMath instance: You get an error message
#79 Posted: 12/19/2025 1:10:36 AM
Phase diagrams with CoolProps. ...
Now can show other thermo properties, and get animations.
PhaseDiagram.sm (46.88 KiB) downloaded 572 time(s).
Animating volume of water and enthalpy of O2.
Вячеслав Мезенцев 12/19/2025 6:44:49 PM, Valery Ochkov 6/23/2026 8:27:38 AM
