Memo Region
Memo Region - Extends SMath Studio with a Memo Region. - Messages
#1 Posted: 5/3/2014 7:49:29 AM
1,550 likes in 1,863 posts.
Memo Region
SMath Studio compatibility SMath Viewer compatibility mono compatibility Extension page Sources
Memo control based on Regions.Control and FastColorerTextBoxCF. Used as an example of the region without a place holder.
Short keys:
Ctrl + A - Select All
Ctrl + C - Copy
Ctrl + V - Paste
Ctrl + X - Cut
Ctrl + U - Upper/Lower Case
Ctrl + Left|Right
Ctrl + Shift + Left|Right
Ctrl + Home
Ctrl + End
Links:
1. Fast Colored TextBox for Syntax Highlighting (Pavel Torgashov).
Martin Kraska 5/3/2014 8:03:00 AM, ioan92 6/16/2014 8:44:00 AM, Davide Carpi 5/3/2014 6:09:00 PM
#2 Posted: 5/3/2014 8:14:49 AM
1,353 likes in 2,265 posts.
Is there a chance for a general rtf region which calls an appropriate editor upon double click either in place or in a separate window? That could partly adress SS-47.
#3 Posted: 5/3/2014 8:31:49 AM
All these editors are based on RichEdit control, which has their own canvas for drawing. We can't use it due to the fact that the components do not support this capability. The only way - do it yourself, like I do it. Another way - wait until Andrey change the input method for the SMath worksheet (he thinks about it).
Other methods will not be portable I think.
Davide Carpi 5/3/2014 6:09:00 PM, Martin Kraska 5/3/2014 9:12:00 AM
#4 Posted: 5/3/2014 12:36:51 PM
Updated. Small improvements.
#5 Posted: 6/16/2014 3:22:54 AM
Updated.
Davide Carpi 6/16/2014 8:43:00 AM
#6 Posted: 6/16/2014 9:50:12 AM
Quote
It reacts at the font size changement but it seems adapted only for font size 10 ?
You can change font with mouse wheel and Control key when region selected.
Quote
In the source that you had indicated it seems that the fonts and the colors (text and background) can be handled (?).
This is not entirely true. Component has no internal data to store information about the properties of the text. Syntax highlighting is performed on the fly. You can not arbitrarily change the color, etc. The only thing what you can do - create highlighting rules.
Quote
Is it imaginable to control this propeties in a similar way as in Davide's plugins (buttons, combobox etc.) ?
I need to see this. If you talk about the properties of the text, as I said above can't modify them.
Not everything works as it should.
Short keys:
Ctrl + C - Copy
Ctrl + V - Paste
Ctrl + X - Cut
Ctrl + Left|Right
Ctrl + Home
Ctrl + End
ioan92 6/16/2014 11:12:00 AM
#7 Posted: 9/18/2018 2:53:35 PM
Updated. Version 0.2.x.x.
Changes:
- xml serialization format changed;
- reworked.
Old versions of the plugin will not be able to open files of a new format.
Disabled until the better implementation.
