units and user functions issue
units and user functions issue - Messages
#1 Posted: 7/9/2012 5:04:08 AM
1,440 likes in 2,928 posts.
Hi
someone can confirm this issue?
seem that:
- it's not related with optimization
- appears only when you redefine an internal variable inside a line() in a user-function, making them dimensionless
best regards,
w3b5urf3r
#2 Posted: 7/9/2012 6:13:45 AM
Hello w3b5urf3r,
This is related to changing the function arguments. As your function is defined as f1(x) and you actually change x then if you call your function with f1(A) then A will change as well. Your function f4(x) actually changed its argument too.
Davide Carpi 7/10/2012 12:55:00 PM
#3 Posted: 7/10/2012 12:34:34 PM
Hello w3b5urf3r,
Hi Omorr
you're right, f4(x) cause the same issue...
I don't know if it's a bug or a feature, but it's quite strange for me... In my mind I think that
the input variable should not be modified, unless the change it's invoked directly (A:=something)
best regards,
w3b5urf3r
#4 Posted: 7/12/2012 10:24:45 PM
kilele
kilele
134 likes in 397 posts.
yes i don't like it either, i mean this global redefinition from within a function, i think this was a change introduced by Andrey for something related to future animation capabilities of smath
#5 Posted: 7/29/2012 2:29:26 PM
2,318 likes in 4,001 posts.
Hello.
Yes, this is by design. This feature called Output Arguments and it can be used within procedures (functions defined with line(..) at right). This allows to return any number of values from the function. One just should remember that changing value for the variable of the same name as defined in function's arguments for such functions will also override global value of that variable.
Regards.
Davide Carpi 7/29/2012 9:17:00 PM
#6 Posted: 10/23/2012 2:05:57 PM
Ruben Sidranski
Ruben Sidranski
17 likes in 465 posts.
I don't get this
I am running into a problem where I have f(x,y):=2x+y When I define x:=? and y:=? I get the correct result. However, WHEN I re-define x and y and reuse the function, the answer is ALL over the place. Can someone give an example explaining what Aundrey ment (see quote)
Michelle Pipe Insulation Rev e.smz (336.41 KiB) downloaded 1063 time(s).
#7 Posted: 10/23/2012 2:19:55 PM
I don't get this
I think that the image below could be useful to explain the behavior
Using f(a) the input variable - x, will be modified by the function;
Using g(a) the input variable - y, doesn't change.
regards,
w3b5urf3r
#8 Posted: 10/23/2012 2:22:43 PM
Ruben Sidranski
Ruben Sidranski
w3b5urf3r
See file I attached while you responded. See the grey non print area for page 2 and 3
#9 Posted: 10/23/2012 2:32:22 PM
w3b5urf3r
I see
It's not related with the behavior of this topic, but with this: local and global variables
Simply change your function giving as input all variable parameters - so add: [MATH lang=eng]k.ins[/MATH],[MATH lang=eng]k.pipe[/MATH] (and others, if needed)
regards,
w3b5urf3r
ElSid 10/23/2012 4:35:00 PM
#10 Posted: 10/23/2012 4:37:48 PM
Ruben Sidranski
Ruben Sidranski
Quote
I had combined various sheets into one sheet and totally spaced the fact that the other variables were changing. Originally, the k's were fixed.
