See the result on the place where the variable is defined
See the result on the place where the variable is defined - Messages
#1 Posted: 11/5/2013 5:19:01 AM
ISO
ISO
0 likes in 2 posts.
I have two little questions.
First if I defined a=5 and b=10, and then if I write c=a+b, is it a problem to see the result in this way c=a+b=5+10=15.
Or the same question but c=a+b=15.
It is a visual problem, but would be helpful
Thanks in advance.
Greetings
#2 Posted: 11/5/2013 7:46:26 AM
1,438 likes in 2,920 posts.
#3 Posted: 11/5/2013 9:28:45 AM
ISO
ISO
0 likes in 2 posts.
Sorry, that I did not check the older topics, but at least that means that this is a wanted feature.
#4 Posted: 11/5/2013 11:34:23 AM
Absolutely yes... I think that The only definition + result, without numerical expansion, would be a fantastic improvement....
#5 Posted: 11/5/2013 3:16:00 PM
Basile
Basile
8 likes in 172 posts.
Can, then, we have a second option to horizontal alignment, a vertical one?
F = m*a = 10 kg * 2 m/s^2 = 20 N
F = m*a
= 10 kg * 2 m/s^2
= 20 N
Thank you,
Basile
#6 Posted: 11/5/2013 3:25:17 PM
1,336 likes in 2,250 posts.
The function Assign() from the Maxima plugin converts a boolean equation into an assignment and displays the result. This is normally used for postprocessing of Solve() and ODE.2() results.
#7 Posted: 11/7/2013 8:40:10 AM
marcofk
marcofk
8 likes in 19 posts.
Does the Maxima plugin work with a portable installation of Maxima? (I have wxMaxima from WinPenPack) Or else, Can you manually set the path to find Maxima?
#8 Posted: 11/7/2013 9:57:28 AM
Yes is possible, look the image attached in the first post of the Maxima Plugin thread
#9 Posted: 11/11/2013 7:24:03 AM
marcofk
marcofk
Thanks very much.
Marco
