Units in variables from a matrix
Units in variables from a matrix - Messages
#1 Posted: 6/11/2023 6:37:44 AM
AR
AR
0 likes in 3 posts.
Hi
I have a dataset (using Excel-file as a source) from where I get values with vlookup, but I am unable to set units properly.
Values retrieved from a matrix have these square brackets around them [], and it makes working with units really difficult.
I was able to convert mm to m (my database has plain values, but they are supposed to be mm). But next step is to display final results in kN/m, but I keep getting kg/s^2.
I am able to remove units completely and display the correct result without units displayed, but this is suboptimal.
EDIT: I'm using importData plugin
#2 Posted: 6/11/2023 9:51:55 AM
Suggestive ...
#3 Posted: 6/11/2023 11:37:52 AM
592 likes in 1,369 posts.
You either need to alter your dataset or do corrections after import.
I am not promising anything but maybe units can be imported as they are.
But we need your dataset and smath file for to check if it can be done.
#4 Posted: 6/11/2023 3:32:41 PM
1,084 likes in 1,758 posts.
... I was able to convert mm to m (my database has plain values, but they are supposed to be mm). But next step is to display final results in kN/m, but I keep getting kg/s^2. ...
Hi. Something like this?
#5 Posted: 6/11/2023 3:52:33 PM
Suggestive ...
... Think in terms of sub-utilities you may need to apply.
#6 Posted: 6/11/2023 6:35:16 PM
My guess is his data is something like this.
That's what I deduce from his description at least.
Without him posting datasheet we can't help any further.
Alvaro 6/11/2023 11:10:00 PM
#7 Posted: 6/12/2023 3:30:41 AM
AR
AR
0 likes in 3 posts.
Thanks for your replies, here are the files.
I would like to display variable z as kN/m instead of that kg/s^2
#8 Posted: 6/12/2023 5:29:17 AM
1,438 likes in 2,923 posts.
You have to customize the result units in the rightmost placeholder.
sergio 6/12/2023 5:44:00 AM
#9 Posted: 6/12/2023 7:01:46 AM
AR
AR
0 likes in 3 posts.
Thank you! I don't know how I didn't get that working couple days ago, I tried to write units outside of brackets but didn't succeed. But now it works no problem
#10 Posted: 6/12/2023 8:43:56 AM
You're welcome
