"Structural Beam Analysis" plugin error
"Structural Beam Analysis" plugin error - Index outside matrix boundaries error - Messages
#21 Posted: 2/5/2020 9:29:37 AM
127 likes in 342 posts.
the plugin now works thanks to Andrey . Unfortunately the diagrams are made exclusively in imperial units; this greatly limits the use and, if I understand correctly, the author has not expressed his intention to continue the maintenance .
#22 Posted: 2/5/2020 12:13:40 PM
Such a joke ! Like the Congress that has not yet defined pi [3 or 4].
#23 Posted: 9/16/2022 8:59:03 AM
Safak
Safak
0 likes in 2 posts.
Hi everyone,
I have been using Smath for many years, but this is my first time writing to the forum
I have a problem with Structural Beam Analysis plugin. I download the Beam Analysis Input Guide from Extansions Manager and didn't change anything in the Smath file.
I couldn't figure out what is causing this situation. Do you have any idea?
Thanks in advance,
#24 Posted: 9/16/2022 10:03:41 AM
churichuro
churichuro
29 likes in 79 posts.
work fine for me, maybe -->
This worksheet requires that the associated Plugin (Structural Beam Analysis
Utility Functions by Redem Legaspi Jr.) be downloaded and enabled from SMath
Studio Extension Manager tool.
#25 Posted: 9/16/2022 10:24:58 AM
Safak
Safak
0 likes in 2 posts.
Thank you for your reply. The plugin was already enabled.
#26 Posted: 9/16/2022 12:20:28 PM
churichuro
churichuro
It's like there's a missing data
#27 Posted: 1/3/2023 2:56:24 PM
oli123
oli123
0 likes in 1 posts.
Hello.
Sources of Beam Analysis Utility Functions stored on SMath server but author of a plug-in asked not to share them.
Several days ago I've got permissions to fix an issue.
Could somebody help me with that?
Plug-in functionality restored now. Tested ok with all available sample worksheets.
New version of a plug-in available using Extensions Manager.
Hi Andrey,
is this plugin source still not shareable? I wanted to modify some of the plotting for my use, such as showing on plot SI units or no unit at all.
#28 Posted: 1/4/2023 7:10:05 AM
1,550 likes in 1,863 posts.
You can use dotPeek to decompile c# assembly (BeamAnalysisUtilityFunctions.dll). Based on these sources, you can write your own plugin. It will be difficult, but you will be able to realize your ideas.
