Solving an eqaution
Solving an eqaution - Messages
#1 Posted: 9/15/2021 10:22:58 AM
Necronomicron
Necronomicron
0 likes in 8 posts.
Hello!
I have an equation (sphere and cubic Bézier curve intersection points): B(t) ⋅ B(t) = r², where dot means vector dot product.
B(t) is a cubic Bézier curve:
B(t) = (1 − t)³ ⋅ P0 + 3t ⋅ (1 − t)² ⋅ P1 + 3t² ⋅ (1 − t) ⋅ P2 + t³ ⋅ P3, 0 ≤ t ≤ 1
P0, P1, P2, P3 are some known points, к is some known value too.
Is it possible to solve this using SMath while keeping constants as letters?
#2 Posted: 9/15/2021 11:08:25 AM
Please attach your Smath document.
Bézier/Hermite ... lot in Smath.
#3 Posted: 9/15/2021 11:49:13 AM
Necronomicron
Necronomicron
0 likes in 8 posts.
https://ru.smath.com/cloud/sheet/ao2a4mLPSz
Well, not much in there, I don't know how to write the equation in it. I am new to SMath, and used only MathCAD a few times, like, 13-14 years ago...
#4 Posted: 9/15/2021 12:19:37 PM
Oscar Campo
Oscar Campo
135 likes in 309 posts.
"Error. There is no Worksheet found."
Please upload your sm file to any cloud service a share the link
Oscar
#5 Posted: 9/15/2021 12:24:03 PM
Necronomicron
Necronomicron
0 likes in 8 posts.
Sphere and cubic Bezier curve intersection points.sm (10.28 KiB) downloaded 861 time(s).
Oscar
#6 Posted: 9/15/2021 1:00:26 PM
Oscar Campo
Oscar Campo
You must use Symbolic evaluation to solve your equation, additionally, you can use some plugin for this task (in my case I used the Maxima plugin).
Please see attached file:
Sphere and Cubic.sm (215.02 KiB) downloaded 868 time(s).
#7 Posted: 9/15/2021 2:21:28 PM
593 likes in 1,370 posts.
All those kind of symbolic solvings require either Maxima or Maple plugin as far as I know.
Every other smath solvers [solve(), roots(), FindRoot(), al_nleqsolve(), etc] are numerical solvers.
Could someone correct this statement if it is not true?
#8 Posted: 9/15/2021 2:33:35 PM
Oscar Campo
Oscar Campo
Every other smath solvers [solve(), Roots(), al_nleqsolve(), etc] are numerical solvers.
yes, that's correct, you can check the description of solve(), roots(), al_nleqsolve(), etc on the Interactive SMath Handbook
#9 Posted: 9/15/2021 8:57:18 PM
1,084 likes in 1,760 posts.
Hi. In the attached how to solve the problem numerically. Notice that B(t) must to be defined using vectorize, because SMath don't expand the scalar by vector products.
Sphere and Cubic.sm (8.86 KiB) downloaded 828 time(s).
Oscar Campo 9/15/2021 9:07:00 PM
#10 Posted: 9/16/2021 6:43:49 AM
Necronomicron
Necronomicron
0 likes in 8 posts.
There is missing «²» after second parentheses in your file. And I downloaded SMath and Maxima, but when I open your file, I get an error: «Cannot find maxima.bat».
Sphere and cubic Bezier curve intersection points.sm (3.77 KiB) downloaded 877 time(s).
#11 Posted: 9/16/2021 7:33:52 AM
Oscar Campo
Oscar Campo
Please refer to Maxima plugin instructions, you can find here
#12 Posted: 9/16/2021 8:18:04 AM
Necronomicron
Necronomicron
0 likes in 8 posts.
OK, I've fixed the error, but now it says: «r is undefined». Sorry, it's really hard to understand what to do and I can't find any proper docs about it...
Sphere and cubic Bezier curve intersection points.sm (4.62 KiB) downloaded 853 time(s).
#13 Posted: 9/16/2021 8:43:30 AM
Necronomicron
Necronomicron
0 likes in 8 posts.
I really don't get what's wrong now...
Sphere and cubic Bezier curve intersection points.sm (12.04 KiB) downloaded 882 time(s).
#14 Posted: 9/16/2021 9:40:26 AM
Oscar Campo
Oscar Campo
There is a missing "*"
#15 Posted: 9/16/2021 11:07:40 AM
Necronomicron
Necronomicron
0 likes in 8 posts.
Thank you! But what should I do with «r is undefined»? 🤔
#16 Posted: 9/16/2021 11:12:25 AM
Oscar Campo
Oscar Campo
Are you sure you are using the option "Symbolic Optimization"?
You must right-click over your equation, then choose Optimization-Symbolic
#17 Posted: 9/16/2021 11:40:06 AM
Necronomicron
Necronomicron
0 likes in 8 posts.
Thank you very much! It worked! However, the roots are so long... Not sure I can use them... Thanks anyway! 😊
#18 Posted: 9/16/2021 2:52:16 PM
Hi. Notice that P0, ..., P3 are vectors with 3 components, not scalars. You can't get the distance with B(t).B(t) using P's as scalars.
#19 Posted: 9/16/2021 8:16:44 PM
Didn't see the sphere ?
Bézier is a 2 D plot
I don't understand your project, will leave.
You can project Bézier as surface plot on the sphere,
at this point, all 'N' are roots.
Enjoy/ignore ... Jean.
Page6 Bezier.sm (30.64 KiB) downloaded 1015 time(s).
#20 Posted: 9/16/2021 9:20:45 PM
Not related with topic. Nice example to Bezier however no relation with question.
Seeing Bezier in question doesn't mean you can search your files and post your first match Bezier example.
fedeghi 9/17/2021 3:24:00 AM
