Solve() Formatting Answer
Solve() Formatting Answer - The Output of Solve() function gives The Output of Solve() function gives division of 2 large number - Messages
#1 Posted: 1/24/2019 10:51:33 PM
Munawar Jakhro
Munawar Jakhro
0 likes in 2 posts.
I am trying to solve 2 eq with 2 variable using Solve() function, the output is division of 2 large numbers which is unusable,
I have tried to find the answer on the forum but cant seem to find anything...
How can I avoid this,
Thanks,
#2 Posted: 1/25/2019 3:56:16 AM
The result is in so called symbolic representation. You can get the numercial answer as well. Just see this is from Interactive book by Martin Kraska (function Solve() in the Maxima plugin). You need Assign() function as well.
Davide Carpi 1/25/2019 5:33:00 AM
#3 Posted: 1/25/2019 3:05:23 PM
1,118 likes in 1,794 posts.
Hi. The use of assign for access to the solutions, as Radovan shows, it's useful if you want the variable names with the solution values. But if not, you can use "at" function, and preserve the variables clean.
frapuano 1/30/2019 8:04:00 AM
#4 Posted: 1/29/2019 8:50:01 PM
Munawar Jakhro
Munawar Jakhro
0 likes in 2 posts.
I would like to thank you all for support.....
I got the answer from from Interactive book by Martin Kraska,
Again Thanks to all ...
#5 Posted: 1/30/2019 10:23:00 AM
You can solve the Engineer way, tracking the upstream dependent(s).
