[Maxima Plugin] is a custom Maxima function call-able in SMath
[Maxima Plugin] is a custom Maxima function call-able in SMath - Can SMath call a custom Maxima function? - Messages
#1 Posted: 5/22/2018 7:06:49 AM
Adriaan Knox
Adriaan Knox
0 likes in 25 posts.
I have defined a function in Maxima but am unable to call it in SMath... I've searched around and tried a bunch of different syntaxes buy am still new to this so if it does indeed work I couldn't get it going... Any help would be appreciated.
Attached are the Maxima .mac file and the SMath file attempting to call it.
func_gradient_divergence_curl.7z (329 B) downloaded 578 time(s).
calling custom Maxima function.sm (4.01 KiB) downloaded 1050 time(s).
#2 Posted: 5/22/2018 10:04:58 AM
Forget what does not work outside of native Smath
Maths Grad_Div_Curl.sm (12.21 KiB) downloaded 1120 time(s).
#3 Posted: 5/22/2018 10:50:39 AM
Jacob.sm (53.35 KiB) downloaded 1094 time(s).
#4 Posted: 5/22/2018 1:32:17 PM
1,353 likes in 2,265 posts.
It seems that there is a conflict with the vector package (load(vect) is executed at maxima startup in the plugin). If you remove that call, then your macro is loaded. I only tried this in wxmaxima. See Insert> Maxima> Log> wxm to see what the plugin does at startup.
