Unable to open sm file - Messages
propped up to continue or quit. I continued, saved and closed.
But now unable to open it. It loads but immediately closes without any message.
Can this be recovered please?
This is the first time I came across this type of an issue.
I use latest WIN 10 64 bit Home edition
TEST.sm (387.7 KiB) downloaded 1404 time(s).
Seems a line break is written wrong to file.
Corrected it with text editor and tried to save under smath to replicate the bug.
Couldn't achieve to bug reappear again.
Code was like this previously.
<p><br>EE</br>Calculate the head losses and the corrected fows in the various pipes of a </p>
<p>EE<br />Calculate the head losses and the corrected fows in the various pipes of a</p>
TEST_rcv.sm (488.99 KiB) downloaded 1433 time(s).
WroteFor information, same behavior with bug under Linux.
Corrected it and tried to save to replicate the bug.
Thank you very much for your contribution.
It saved me a lot of trouble.
I've had this issue before. Thanks for the fix, the last time this happened, I had a backup. The funny thing is, per HTML code, the first screenshot looks "more" correct.WroteFor information, same behavior with bug under Linux.
Code was like this previously.Revised to this with text editor.<p><br>EE</br>Calculate the head losses and the corrected fows in the various pipes of a </p>Regards<p>EE<br />Calculate the head losses and the corrected fows in the various pipes of a</p>
NDTM, I spotted what appears to be minor spelling error. FLOWS, not FOWS
WroteI've had this issue before. Thanks for the fix, the last time this happened, I had a backup. The funny thing is, per HTML code, the first screenshot looks "more" correct.
Yes. Thank you. Now I made the correction.
WroteWhenever I try to edit contents of some description boxes the unhandled exception error message props up. For information of Developers please.
Please attache the content of the "Details" window.
WroteThe funny thing is, per HTML code, the first screenshot looks "more" correct.
IDK I'm only an amateur HTML coder but to me
always has been a void/empty element; looking at standards:
In the orginal HTML (up to 4.01) only
is correct;
In XHTML
and
are allowed,
is not allowed.
In HTML 5 only
and
are allowed,
is not allowed.
something was newer allowed, so it seems an encoding bug to me.
Details Window.txt (30.14 KiB) downloaded 1004 time(s).
Pipe_Network_EX_HARDY_CROSS.sm (299.12 KiB) downloaded 1313 time(s).
Most accurate and informative answer.
