problem with "str2num"
problem with "str2num" - the function is not evaluated correctly - Messages
#1 Posted: 6/17/2019 1:36:00 PM
127 likes in 342 posts.
I need to evaluate a condition (Boolean) that I have to build on a case-by-case basis. In testing this situation, I experienced the incorrect behavior of the "str2num" function in the case of the "=" sign.
str2number_z.sm (4.22 KiB) downloaded 1155 time(s).
#2 Posted: 6/17/2019 8:22:08 PM
Clearly a bug it does not recognize 'Numeric'
#3 Posted: 6/17/2019 8:42:28 PM
1,550 likes in 1,863 posts.
Try this.
sergio 6/18/2019 6:14:00 AM, NDTM Amarasekera 6/18/2019 6:20:00 AM
#4 Posted: 6/18/2019 5:36:23 AM
thank you uni, it's a good buffer solution; only a minimum discomfort remains for entering the correct character.
