How i can write this formula in Smath Studio?
How i can write this formula in Smath Studio? - How i can write this formula in Smath Studio? - Messages
#1 Posted: 5/18/2018 10:05:41 AM
yuriy1996
yuriy1996
0 likes in 11 posts.
I have one formula where it is necessary to make a sum in a way that takes into account 5 coefficients of a polynomial. In the sum he is marked as ak and I need that instead of ak there was a1..a2..a3 ... a4 ... a5. Also, for each polynomial account, the power K automatically changes from the index of the polynomial 1..2..3..4..5. How to implement it in this program? Also, I have several layers of reinforcement in the equation that should also be instead of Asi to As1...As2...As3...Asn and Sigma_si to Sigma_s1...Sigma_s2...Sigma_s3...Sigma_sn . Sorry for bad English.
Arkush1.sm (11.61 KiB) downloaded 773 time(s).
#2 Posted: 5/18/2018 10:32:44 AM
120 likes in 337 posts.
You made the following error: you used "a.k" instead of "a[k". This way you did not create vectors to use in the summation with the counter. You need to do to define and then use As and Sigmas.
yuriy1996 5/18/2018 11:16:00 AM
#3 Posted: 5/18/2018 10:38:06 AM
yuriy1996
yuriy1996
I corrected a.k for a[k but how do I set 5 values for one variable a[k?
#4 Posted: 5/18/2018 10:55:32 AM
for example a[1:=2.5 a[2:=3.21 a[3:=-7.1
so "a" is a vector
in the sum a[k
yuriy1996 5/18/2018 11:15:00 AM
#5 Posted: 5/18/2018 11:13:48 AM
yuriy1996
yuriy1996
Unable to determine the value of an element since the item with the specified index does not exist -error
#6 Posted: 5/18/2018 11:16:25 AM
yuriy1996
yuriy1996
Arkush1.sm (14.27 KiB) downloaded 786 time(s).
#7 Posted: 5/18/2018 11:46:35 AM
CBG
CBG
78 likes in 312 posts.
Solution
Arkush1_CBG.sm (15.8 KiB) downloaded 780 time(s).
Carlos
yuriy1996 5/18/2018 11:49:00 AM
#8 Posted: 5/18/2018 12:29:55 PM
... you may clean/recast a bit.
Arkush1_CBG.sm (13 KiB) downloaded 804 time(s).
#9 Posted: 5/18/2018 1:18:18 PM
You have 11 sets of 'a'
Easy to tabulate, is it what you want ?
#10 Posted: 5/18/2018 1:51:50 PM
NDTM Amarasekera
NDTM Amarasekera
130 likes in 352 posts.
Pl look at this. Error may have occurred when entering the formula???? Difficult to trace.
Unable to select individual components of the erroneous formula.
Arkush1_ndtma.sm (16.76 KiB) downloaded 795 time(s).
#11 Posted: 5/18/2018 2:53:49 PM
Arkush1_CBG [data].sm (136.18 KiB) downloaded 655 time(s).
#12 Posted: 5/18/2018 9:34:10 PM
There it seems the formula is ill posed wrt [4.1].
It shows bfcd as something not defined but the originator
has defined b, and defined fcd ... b*fcd.
