how can i get a value depending on a COMBOLIST
how can i get a value depending on a COMBOLIST - i need to get the value of "zg", example when i select in the comblist "D", zg=213.36 - Messages
#1 Posted: 5/26/2021 11:45:01 AM
mnorena
mnorena
0 likes in 13 posts.
#2 Posted: 5/26/2021 12:01:14 PM
1,442 likes in 2,935 posts.
the output of your choice is stored in the variable set on the region placeholder (in your case, c_expo)
You can choose the output values in a range of options depending on your needs (righ click and choose "Settings" from context menu or double-click on the region, then set an output option).
To get directly the value, in your example you have to choose "nth element in the row" and then the 2nd column.
#3 Posted: 5/26/2021 12:10:52 PM
mnorena
mnorena
thank you
#4 Posted: 5/26/2021 6:20:26 PM
26 likes in 155 posts.
#5 Posted: 5/27/2021 9:53:25 AM
Set your matrix algo style, to accommodate any matrix.
Cheers ... Jean [SS 6179]
Utilities Matrix Algo Style Extract.sm (30.67 KiB) downloaded 977 time(s).
#6 Posted: 5/27/2021 10:39:15 AM
... add the bloc extract.
