Plotting strings - Messages
When I want to plot text/strings, I add mat(1;5) to my graph. Strings usually has top left justification.
Is it possible to set justification as the sixth element of the matrix?
WroteWroteIs it possible to set justification as the sixth element of the matrix ?
No need AFAIK.
Hello Jean,
Take a look at the attached image. I want C to have top right justification, and B bottom right. I could just offset the coordinates for a quick fix, but when I change the zoom level that will not work.
Best regards,
WroteHello Jean,
Best regards,
For fixed rotation, you can get inspired from the attached.
Smath is not a CAD, but from little it does so much.
This W Truss originates from Ioan [SS 5346 ?]
End result from multiple collaboration [Alyles, Carlos, Jean].
Next from you: *.sm document.
Utilities XY [Draw Truss Labels ZOOMED mode].sm (26.56 KiB) downloaded 1278 time(s).
Jean,
Your example seems to work well when zooming out. When zooming in the labels starts getting further appart fram the drawing.
I was hoping maybe this was something the developers could incorporate in an upcoming release.
Best regards,
You are asking a CAD functionality that does not have much interest.
This triangle has some curious relationship.
Most probably each figure will have more surprises + rotation.
What is the interest of zooming a triangle ?
That one, you can zoom/rotate at will for [Area/Perimeter/CG]
[Area/Perimeter/CG] for any figure of XY vertices.
Where are you in your design ? ... Jean.
Jean,
I was just puzzling around with trigonometry. I never seem to remember the trigonometric relationships, so rather than googling 'trigonometric functions' all the time, I figured it would be fun to try to make something in SMath.
Attached is the "project" I was fooling around with. I tried to plot an angle (L) in all the corners that were 90°, but because of the significant round-off errors I skipped that part.
Best regards,
Trigonometry.sm (39.97 KiB) downloaded 1365 time(s).
WroteAttached is the "project" I was fooling around with. I tried to plot an angle (L) in all the corners that were 90°, but because of the significant round-off errors I skipped that part.
This is a very good example.
Nice job, kudos to your project.
Thank you, far too kind!
Best regards,
WroteYour zoomed triangle is pure success from brute force refactoring.
Sorry for the 5 hours power failure from unusual strong wind.
Thanks for this nice project ... Jean
Trigonometry.sm (49.98 KiB) downloaded 1471 time(s).
I guess zooming in and out on the plot could be avoided by resizing the triangle within the plot.. and that way shifting/aligning the labels manually will work just fine.
Best regards,
Medians [med] approximate, not from calculations.
More maths added for convenience.
Thanks for that superb Classroom ... Jean
Utilities XY [Draw ZOOM Triangle].sm (20.36 KiB) downloaded 1233 time(s).
WroteLast brick in the wall for that one.
Jean,
Very interesting! Thanks for the insight.
Best regards,
WroteVery interesting! Thanks for the insight.
... added rotation of a new triangle.
Take care ... Jean
Utilities XY [Draw ZOOM Triangle] Copy.sm (47.22 KiB) downloaded 1308 time(s).
