Plugins crash in Smath Studio 0.99.7679
Plugins crash in Smath Studio 0.99.7679 - Meta TagsEditor and Text RegiosUtilitues plugin crash - Messages
#1 Posted: 1/8/2021 11:53:31 PM
CBG
CBG
78 likes in 312 posts.
Hello
The following plugins crash in Smath Studio 0.99.7679
Carlos
sergio 1/9/2021 6:08:00 AM
#2 Posted: 1/9/2021 10:40:56 AM
netsonicyxf
netsonicyxf
2 likes in 79 posts.
I have the similar issue:
#3 Posted: 1/9/2021 11:15:51 AM
2,318 likes in 3,973 posts.
I will update these plug-ins soon.
#4 Posted: 1/9/2021 12:03:10 PM
netsonicyxf
netsonicyxf
Is it possible to add a button to temperally disable plugins so they don't get loaded at startup but still can be checked for update?
#5 Posted: 1/9/2021 12:42:03 PM
Currently it is not possible.
#6 Posted: 1/10/2021 8:27:24 PM
mMath Files and Knovel Meta Tags Editor plug-ins fixed.
#7 Posted: 1/10/2021 11:49:28 PM
CBG
CBG
Thank you.
Thank you.
But the Text Region Utilities plugin keeps crashing
Carlos
#8 Posted: 1/11/2021 7:40:46 AM
netsonicyxf
netsonicyxf
When installing them through plugin manager, both of them shows "plugin installation fails"
#9 Posted: 1/11/2021 10:00:52 AM
Looking at the screens hot you provided it seems that you have plug-ins installed by manual copy of dll files.
You need to delete such plug-ins first and then install then from Extension Manager.
#10 Posted: 1/11/2021 1:46:54 PM
1,436 likes in 2,916 posts.
Thank you, I'll try to fix it ASAP.
#11 Posted: 1/13/2021 8:17:43 PM
Davide, I've forgot to make some reviewed Fields public, so it was just impossible to fix the plug-in. Now it is done.
Fixed.
Davide Carpi 1/14/2021 4:07:00 AM
#12 Posted: 1/13/2021 8:49:04 PM
Ruben Sidranski
Ruben Sidranski
17 likes in 463 posts.
UNI's EFI plugin is crashing too.
My new portable install has no plugins at the moment
Should I remove it per 0.99.7610 is available
#13 Posted: 1/13/2021 10:01:00 PM
Strange. Just checked EFI plug-in - it loaded correctly in my SMath Studio installation.
#14 Posted: 1/14/2021 4:08:26 AM
Thank you Andrey
#15 Posted: 1/14/2021 12:30:41 PM
Ruben Sidranski
Ruben Sidranski
As you see from the screenshot above, I'm using version 7610 (portable version). I uninstalled the plugin and reinstalled. The install went well and no errors. However, once I restart SMath, the error pops back up.
Could it be a portable version issue?
