Simple calculation is producing the wrong answer
Simple calculation is producing the wrong answer - Adding up negative an positive numbers - Messages
#1 Posted: 5/1/2012 7:42:08 AM
lcesero
lcesero
0 likes in 8 posts.
I have come across an error when doing the folowing calculation.
-5.00+.85+.85+3.30=-4.44*10^-16 ( decimal places are set to 2)
The above equation should equal zero.
I am using the portable version .93 (build 4466 ) on Windows 7 Pro 64bit.
Thanks in advance.
#2 Posted: 5/1/2012 2:11:55 PM
lcesero
lcesero
0 likes in 8 posts.
I was wondering if anyone else can reproduce this symptom.
Thanks,
#3 Posted: 5/1/2012 2:21:12 PM
2,335 likes in 4,033 posts.
Hello lcesero.
Yes, I've reproduced it. The only thing I can do here is to add an ability to replace answer with 0 if the result accuracy is less then or equal [MATH]10^-16[/MATH]. This way used by Mathcad as an option of every equation. Will think about it.
Best regards, Andrey Ivashov.
