solving simultaneous equations with Solve
solving simultaneous equations with Solve - Solve() Maxima not working - Messages
#1 Posted: 4/5/2022 3:45:27 PM
Mo
Mo
0 likes in 34 posts.
hi,
I used the Solve function a lot before but for some reason it does not work for this simple example.
I need to get the RayLeigh Damping factors alpha and beta using two frequencies, so two simple simultaneous equations should do it. tried using Solve but no luck.
Does anyone know why it is not solving?
Thanks in advance
#2 Posted: 4/5/2022 4:39:40 PM
127 likes in 342 posts.
Show Spoiler
test_sergio.sm (8.05 KiB) downloaded 1039 time(s).
Mo 4/5/2022 10:22:00 PM
#3 Posted: 4/5/2022 6:24:50 PM
598 likes in 1,379 posts.
You can use roots() for your function. And a vectorize() can simplify it.
However, to use Assign() you will need this function to merge vars and solutions.
Assign_without_Maxima Solve().sm (7.36 KiB) downloaded 1100 time(s).
#4 Posted: 4/5/2022 10:22:48 PM
Mo
Mo
Thanks Overlord, PompelmoTell, greatly appreciated!!
#5 Posted: 4/6/2022 10:28:07 AM
⚜ Kenny Lemens, P.E. ᵂᴵ
85 likes in 179 posts.
Greetings,
Another approach would be to use some elbow grease, you can substitute terms by hand and solve for 𝛼 and 𝛽:
Keypress (You can copy/paste the following into your worksheet):
α:{2*D*ω.1*ω.2}/{ω.1+ω.2}
β:α/{ω.1*ω.2}
*NOTE: ω.1 and ω.2 shown above are variables with subscript, they are not vectors ω[1 and ω[2; You should be able to substitute ω.1 for ω[1 if that serves your purposes.
- Kenny Lemens, P.E.
Mo 4/6/2022 11:57:00 AM
#6 Posted: 4/6/2022 11:40:36 AM
Fridel Selitsky
Fridel Selitsky
520 likes in 451 posts.
If the damping coefficients are denoted by α1 and α2, you can use the function al_nlegsoive
test.sm (6.99 KiB) downloaded 1124 time(s).
sergio 4/6/2022 12:26:00 PM, Mo 4/6/2022 11:57:00 AM
#7 Posted: 4/7/2022 11:08:53 AM
Fridel Selitsky 4/7/2022 11:54:00 AM
#8 Posted: 4/7/2022 1:43:03 PM
... more in there from native Smath code.
Solve FindRoot FORUM.sm (10.9 KiB) downloaded 1101 time(s).
#9 Posted: 4/7/2022 5:27:55 PM
solving with uni's latest addition mathcad blocks;
you wouldn't need Eq: actually, but it can be shown.
mathblock.sm (5.15 KiB) downloaded 1099 time(s).
Mo 4/9/2022 10:28:00 PM
#10 Posted: 4/7/2022 6:19:34 PM
I think this is the most sophisticated method of my way.
It can get unknowns from equation, solve them.
In the end assigns numerical values to unknowns.
You don't need to define alpha or beta or any variable.
All process is automatic.
mathblock_v2.sm (5.19 KiB) downloaded 1099 time(s).
There is also this way for guess define.
#11 Posted: 4/8/2022 2:19:42 AM
Fridel Selitsky
Fridel Selitsky
This is good, but for a system of linear equations(our case), the guess can be arbitrary.
#12 Posted: 4/8/2022 8:04:07 PM
1,353 likes in 2,265 posts.
And finally a version with Solve() and list injection region:
mathblock_Solve.sm (4.86 KiB) downloaded 1065 time(s).
sergio 4/9/2022 4:48:00 AM
#13 Posted: 4/11/2022 9:57:44 AM
Greetings,
If plugins are considered, you can also consider the use of Maple:
In the image I posted, the 'equal sign' shown on those two equations are actually symbolic equals; keypress: [ctrl] + [.] instead of keypress [=].
Kenny Lemens, P.E.
#14 Posted: 4/11/2022 4:44:08 PM
1,118 likes in 1,794 posts.
Hi. The isol solution, using only the Mathcad block plugin.
isol_example.sm (68.13 KiB) downloaded 1053 time(s).
isol_example.pdf (34.57 KiB) downloaded 562 time(s).
sergio 4/12/2022 5:01:00 AM
#15 Posted: 4/14/2022 12:10:17 PM
Mo
Mo
Thank you all for the feedback, is there a literature or manual to explain the Mathcad block plugin?
Thanks
#16 Posted: 4/14/2022 2:54:00 PM
Thank you all for the feedback, is there a literature or manual to explain the Mathcad block plugin ?
For that particular example, maple is an algebraic export.
Mathcad block has not yet been exemplified in Smath Community
of what it can do vs what native Smath can't.
Codes Solve.sm (12.46 KiB) downloaded 1093 time(s).
#17 Posted: 4/14/2022 7:43:45 PM
Exercise the Mathcad bloc
#18 Posted: 4/14/2022 8:19:07 PM
Thanks
We have what Viacheslav provided us.
There are some samples or functions too which individual users uploaded.
You can look the extension page for some examples.
And there are some samples in forum topic that users posted.
It may be a small bunch, but we try to understand its capabilities.
This feature/plugin is also new to us.
https://en.smath.com/forum/yaf_postst726_Mathcad-Toolbox.aspx
