Problem Dividing Second Term With Units
Problem Dividing Second Term With Units - user interface - Messages
#1 Posted: 7/4/2016 9:39:30 PM
ISawThatToo
ISawThatToo
0 likes in 1 posts.
sMath Studio: 0.98 (5935)
I am trying to enter the equation at the top of page 17 of this intro guide:
https://smath.com/wiki/GetFile.aspx?File=Tutorials/IntroductionSMathStudio088May2010.pdf
formula
The first multiplicand with units goes in fine, as does the numerator with units of the second multiplicand. However, SMath Studio will not permit me to enter a denominator under the full numerator (value and units) of the second multiplicand.
When I press the space bar, various objects become underlined, but never the entire numerator (with units) of the second multiplicand:
Problem
I then am unable to enter the denominator under the complete numerator (value with units) of the second multiplicand.
Is this a bug, or user error? How to fix?
Note: I can enter the values, and then return and enter the units, but I would prefer to do it in one pass.
Thanks.
#2 Posted: 7/5/2016 12:14:34 AM
Does not work for me either. 2010 is pretty old ....
Now it works but it has do do with the exponential threshold, but not mentionned at all
μN => exp threshold [6]
mN => exp threshold [3]
N => exp threshold [9]
No problem to enter the denominator. Open brackets first, type the stuff, square
Cheers collab.
#3 Posted: 7/5/2016 6:40:15 AM
1,438 likes in 2,920 posts.
I think that should be considered a bug or at least a missing feature in the user interface.
When you write a new formula: add a division before writing the second multiplicand
2.5 ► 'mg ► [space or right arrow] ► * ► / ► [numerator] ► [right arrow] ► [denominator]
To edit an existing formula probably the fastest way is to transit through the plain text (copy the whole formula in a text region or in notepad, wrap the multiplicand in curly brackets, copy and paste back as math -> the multiplicand will be selectable)
2.5*'mg*{10.5*'ft}
#4 Posted: 7/5/2016 9:42:26 AM
Yes David,
for this case with units, I should have written:
1. edit the firt term
2. call *, call divide
3. edit numerator
4. edit denominator: Open brackets first, type the stuff, square
5. edit result from the unit menu
6. finish editing the result
