While loop never ends
While loop never ends - Messages
#1 Posted: 3/13/2020 3:27:06 PM
Yes Man
Yes Man
0 likes in 6 posts.
Hi everyone, I've got problem with while loop. I have this function with Xstart = 0.2 ; Xfinish = 2 ; deltaX = 0.2 and I need to solve it in smath studio, but while loop is processing forever and never ends. I'm doing something wrong, or it's a bug? Thanks!
Images:
https://postimg.cc/Q9mqWkKd Smath studio
https://postimg.cc/KKZkgXPt Function I need to solve
#2 Posted: 3/13/2020 4:58:44 PM
NDTM Amarasekera
NDTM Amarasekera
130 likes in 352 posts.
Is this what you need?
#3 Posted: 3/13/2020 5:14:41 PM
Yes Man
Yes Man
0 likes in 6 posts.
No, I need a range of numbers for X and Y, like: First X = 0.2, it's calculating Y(0.2) and shows first Y result, then X = 0.4 (previous X + delta X) and it's calculating Y(0.4), and until x = 2. In final I need a range of all X and all Y results.
#4 Posted: 3/13/2020 5:30:47 PM
Some examples ...
Utilities Pts Critical Monte-Carlo.sm (18.33 KiB) downloaded 1005 time(s).
Utilities Program While FindIndex.sm (34.87 KiB) downloaded 990 time(s).
#5 Posted: 3/13/2020 5:55:24 PM
Yes Man
Yes Man
0 likes in 6 posts.
Some examples ...
I'm not sure I understood how to solve my function by this examples.
I don't know what I'm doing wrong:
#6 Posted: 3/13/2020 8:38:39 PM
Your proposal is not a case of while loop,
strictly wrong application.
Page44 Unknown.sm (73.22 KiB) downloaded 1184 time(s).
#7 Posted: 3/14/2020 6:06:47 AM
1,353 likes in 2,265 posts.
You can do the job using a while loop but it is just one option (perhaps not the most straightforward one).
loops.sm (10 KiB) downloaded 1024 time(s).
Davide Carpi 3/14/2020 7:20:00 AM, frapuano 3/14/2020 8:38:00 AM, sergio 3/14/2020 2:01:00 PM
#8 Posted: 3/14/2020 6:19:48 AM
Yes Man
Yes Man
0 likes in 6 posts.
I need all X and all Y(x) values in the end, for Xfirst = 0.2, Xlast = 2 with step 0.2.
y(0.2)=
y(0.4)=
y(0.6)=
y(2)=
And it should look something like this:
x= 0.2 y= -0.6126
x= 0.4 y= 0.2173
x= 0.6 y= 0.7064
x= 0.8 y= 1.0721
x= 1.0 y= 1.3842
x= 1.2 y= 1.6771
x= 1.4 y= 1.9738
x= 1.6 y= 2.2924
x= 1.8 y= 2.6501
x= 2.0 y= 3.0639
I can type every y(x) in smath studio:
https://postimg.cc/0bddLTqF
But, is it possible to do it with while loop?
#9 Posted: 3/14/2020 6:21:13 AM
Yes Man
Yes Man
0 likes in 6 posts.
y(0.2)=
y(0.4)=
y(0.6)=
y(2)=
x= 0.2 y= -0.6126
x= 0.4 y= 0.2173
x= 0.6 y= 0.7064
x= 0.8 y= 1.0721
x= 1.0 y= 1.3842
x= 1.2 y= 1.6771
x= 1.4 y= 1.9738
x= 1.6 y= 2.2924
x= 1.8 y= 2.6501
x= 2.0 y= 3.0639
#10 Posted: 3/14/2020 8:25:47 AM
What you are asking for is so restricted and useless for purpose !
Then you can:
1. start wherever [L] as long as computable your ln(,)
2. end wherever [N]
3. as fine step size [Δ]
4. algo style for infinite applications
#11 Posted: 3/14/2020 8:52:29 AM
Yes Man
Yes Man
0 likes in 6 posts.
Then you can:
2. end wherever [N]
I'm asking for this cos' we are learning Pascal programming language in university, and we need to write this function in Pascal with [while a<=b do], and check it in MathCAD or SMath studio program.
I don't need any graphics, I just need to check the function with while loop. You sent example without while loop and without Xlast = 2, so is it possible to check this function with while loop, or no?
#12 Posted: 3/14/2020 10:11:42 AM
Pascal is pretty retarded these days for Engineering applications !
Years ago, Mathcad for Universities was pretty freaked.
Better use Smath productive for studies & Engineering.
Golden ratio will be a life time productive Companion.
As well as an advanced WhileLoop.
Golden Ratio jmG.sm (39.41 KiB) downloaded 973 time(s).
#13 Posted: 3/14/2020 11:20:50 AM
1,442 likes in 2,935 posts.
Absolutely, and there are several ways.
If you need a step-by step feedback on the fly you can use breakpoints (menu of math regions) and the debugger window ("View" menu). You might have to store the intermediate results in a dedicated variable though, to don't look into the whole matrix at each step.
Also you can use the function trace() and the output window, or you can build math strings using concat() and other functions, or maybe something more complex using the script region plugin by uni.
loops-1.sm (30.01 KiB) downloaded 937 time(s).
sergio 3/14/2020 2:35:00 PM, frapuano 3/14/2020 4:00:00 PM, SteelCat 5/17/2020 3:51:00 PM
