Combobox with Variable Selection
Combobox with Variable Selection - Is it possible to create a Combobox with variable input - Messages
#1 Posted: 3/12/2017 6:10:51 PM
Ryan Freund
Ryan Freund
20 likes in 339 posts.
Is it possible to create a combobox that has a variable matrix. Meaning if x use Y matrix, else use Z matrix.
See attached. I have 2 matrices. Depending on what is selected from a different combobox I'd like to change the matrix that the next combobox uses.
I understand that I can put the "if statement" between the comboboxes but this doesn't look as clean
Thanks in advance!
Combobox List - variable matrix.sm (10.39 KiB) downloaded 1121 time(s).
Edit_1:
Note - If actually using this for Masonry the if statement is incorrect. This doesn't matter for the question at hand though
#2 Posted: 3/12/2017 7:52:44 PM
1,442 likes in 2,935 posts.
But actually you have the if statement, right before the first combobox; how it is more clean?
If you use a line() on MMCS, then you can place MMCS:MMCS out of the right margin after the first combobox making it available for the 2nd combobox. If you need to reuse it, you can define MMCS as a function MMCS(MUM), and then you can define MMCS:MMCS(MUM) after the first combobox (below or out of the printing bounds)
