LM Algorithm !!
LM Algorithm !! - Messages
#1 Posted: 7/3/2019 5:03:43 AM
shinavn
shinavn
0 likes in 2 posts.
For this particular example, Carlos algorithm spits out in < hart beat !
Thanks again Carlos, it will surely help revamp some/many of the GenfitMinimize.
Shina
#2 Posted: 7/3/2019 9:51:17 AM
Shina
Could you be more specific please. What example are you talking about?
Davide Carpi 7/3/2019 10:32:00 AM
#3 Posted: 7/3/2019 11:51:07 AM
Please, share your application.
LM covers a good % of all fits in Mathcad.
Cases LM fails, Conjugate Gradient is the sole rescue.
Many model functions can only be fitted by hand.
#4 Posted: 7/10/2019 10:05:59 AM
Shina
You are right About LM, however not so simple.
al_nleqsolve, LM, ConjugateGradient that produce in Smath, all dependent
upon initials and reflexivity of the model +++ the approach technique.
Data reduction is a great approach technique [Kirby, Thermocouples ...]
In Mathcad LM as well as CG, a technique that works well to initialize
wrt many models is to pass manually initials through 2 points.
That was not explored with Carlos LM.
That technique through 2 points did work well in some Smath fit,
but failed in other fits. Maybe you are working hard on that stuff ?
Attached for the interest of this visit.
Genfit Chemist.sm (34.16 KiB) downloaded 1098 time(s).
Genfit Minimize Rational KHL.sm (45.36 KiB) downloaded 1067 time(s).
Genfit Pharmacokinetics.sm (41.84 KiB) downloaded 1092 time(s).
#5 Posted: 7/11/2019 10:38:07 AM
... for your delight => try Laser
Genfit Convolution Laser.sm (231.03 KiB) downloaded 1134 time(s).
