Pick a number from a list if condition is meet
Pick a number from a list if condition is meet - Messages
#1 Posted: 3/12/2024 3:31:22 PM
Alex Costila
Alex Costila
1 likes in 13 posts.
How can i pick a speed based on a "n" value.
Let's say my n= 13 i want to get the value 30km/h for V, but if its 8 i want 60km/h.
I have tried with for/while/if. But im guessing im doing something wrong or i don't know what to write exactly.
Any help is much apprecite it!
#2 Posted: 3/12/2024 5:18:17 PM
1,350 likes in 2,262 posts.
Worksheet6.sm (4.8 KiB) downloaded 1215 time(s).
#3 Posted: 3/12/2024 5:41:24 PM
Alex Costila
Alex Costila
Thank you for the answer, but this doesn't help me. Or i don't understand it .
Example, i have N=10, based on N i want to get V. V for N=10 it's from here:
, but if i change N to 9 i want to obtain V=30km/hr.
Thing is i have 8 variable based on N, and i want to obtain the values only by changing N.
Sorry if i don't explain very well.
#4 Posted: 3/12/2024 6:28:42 PM
The procedure is to get a vector of the potential values which can then be accessed by index.
You also could implement it as a function v(n) = 30 + mod(n-1, 4)*10
#5 Posted: 3/12/2024 6:51:40 PM
Alex Costila
Alex Costila
Great it works now. I just have to figure it out how to implement it for the rest of the file .
Thank you very much!
How would you tackle this one?
#6 Posted: 3/12/2024 8:52:27 PM
Divide n by 2, a bit of rounding and offset adjustment should do the job.
#7 Posted: 3/18/2024 8:26:30 PM
Alex Costila
Alex Costila
I can't seem to get it to work, and for next examples i need to match it with a list that has some randomnes in number list. Isn't there a way i can create a list of number and if my "n" matches that list then i can get the correct value? I tried with for, if and so on. but im still a newbie in Smath.
Thank you once again!
#8 Posted: 3/18/2024 9:19:04 PM
1,440 likes in 2,928 posts.
If you have a limited set of choiches, this might be a solution.
Also, I think Martin has a point, since these "n" values should come from some formula.
#9 Posted: 3/19/2024 2:10:00 AM
If there is no rule, then you have to provide a vector with values and adress it with index n. A simple lookup table by index. Fill the vector by hand, by reading a file or asking a chatbot.
#10 Posted: 3/19/2024 2:49:03 PM
Alex Costila
Alex Costila
This works but i have other areas with diferent increment and i can't control them with interval. I will list a few of them:
here is 1,2,3 then goes to 16,17,18 then 26,27,28.
So i have this interval from the picture above and the one before with "Latimea benzii".
#11 Posted: 3/19/2024 3:57:49 PM
Alex Costila
Alex Costila
Found a not very fancy solution, but it works .
pick a number from a list.sm (6.25 KiB) downloaded 1155 time(s).
