Triangle-Circle-Newton
Triangle-Circle-Newton - What is wrong? - Messages
#1 Posted: 2/17/2024 2:50:02 PM
Valery Ochkov
Valery Ochkov
66 likes in 690 posts.
Hi all!
I'm trying to solve a problem about a circle inscribed in a triangle using Newton's method. The Root function does not work.
I have some questions with how muted operators work - I don't want to set the value n - I want to use a hybrid operators for and while.
What am I doing wrong?
Triangle-Circle-Newton.sm (143.31 KiB) downloaded 1372 time(s).
See please more https://community.ptc.com/t5/Mathcad/Malfatti-circles/td-p/687281
https://community.ptc.com/t5/image/serverpage/image-id/31378i6EB179E7EF72B74C/image-size/large?v=v2&px=999
#2 Posted: 2/17/2024 10:11:37 PM
1,353 likes in 2,265 posts.
Hi, first of all you have to keep hands off i if you handle complex numbers. Don't use it as iterator variable.
Second, I am not sure what for(4) actually does. Unfortunately I can't break down it to a minimum working example. The disabled region should work as the for(3) loop with exit condition but it doesn't (somehow gets stuck). Tests with trace showed that inside the for(4) loop the arithmetics seem to be rotten. For comparison I added a loop-free implementation of the algorithm by just repeating the commands in the sheet.
Once one accepts the complex numbers, the algorithm converges to a reasonable solution. Yet, the radius turns out negative for the given initial guess. This can happen because only the square of the radius occures in the model.
Triangle-Circle-Newton_kr.sm (194.62 KiB) downloaded 1351 time(s).
Valery Ochkov 2/18/2024 4:47:00 PM
#3 Posted: 2/17/2024 10:23:08 PM
Augmented version of the original MCD 11
Maths Triangle ScaleneInscribed.sm (41.99 KiB) downloaded 1369 time(s).
#4 Posted: 2/18/2024 12:10:33 AM
StvMath
StvMath
44 likes and 1 dislikes in 71 posts.
I don't think you've actually adopted the KISS principle here Valery! The attached seems much simpler.
Triangle-Circle-Newton_stvmath.sm (116.79 KiB) downloaded 1295 time(s).
