Snippet Operations with units Fail
Snippet Operations with units Fail - Fails on some occasions to detect the units - Messages
#1 Posted: 5/16/2022 7:05:41 PM
CBG
CBG
78 likes in 312 posts.
Hello
The unit operation snippet fails to detect units.
Snippet_Units_Fail.sm (33.04 KiB) downloaded 1401 time(s).
Carlos
#2 Posted: 5/17/2022 9:02:34 AM
1,442 likes in 2,935 posts.
Try this
Snippet_Units_Fail.sm (32.38 KiB) downloaded 1327 time(s).
#3 Posted: 5/17/2022 9:12:04 AM
Hola Carlos ... Jean...OK SS 6179
#4 Posted: 5/17/2022 4:51:34 PM
CBG
CBG
Hello David
Quote
Try this
Thank you very much for your answer, but the snippet fails, since instead
of finding the units, it only obtains the value of 1
Hola Jean
Saludos
Carlos
#5 Posted: 5/18/2022 4:44:35 AM
Hello David
My bad, IDK why but yesterday seemed to work to me, but in fact it doesn't. I'll give another look at the snippet ASAP.
#6 Posted: 5/18/2022 2:00:44 PM
I see the issue. The function look for a numerator/denominator pattern in the num2str() text, but doesn't handle cases in which multiple divisions are involved.
#7 Posted: 5/18/2022 10:47:59 PM
CBG
CBG
Hello David
Thank you very much for your attention, I hope the Snippet has a fix-
On the other hand, I ran the snippet in version 6179,
and it works perfectly. How is that possible?
Carlos
#8 Posted: 5/19/2022 8:28:50 AM
I'm not sure, however if you need a urgent fix here you have an easy way to make it working the same way.
