RC2: 0.99.6654 (22 March 2018)
RC2: 0.99.6654 (22 March 2018) - Messages
#1 Posted: 3/21/2018 6:47:14 PM
2,318 likes in 4,001 posts.
Changes introduced in current build 0.99.6654
Improvements
  • Added ability to install plug-in using drag'n'drop of downloaded zip-archive into SMath Studio window.
Corrections
  • Fixed unwanted scrolling on copying Region using Ctrl+Move by mouse taking Region by it's border;
  • SS-3517: Setting of matrix elements using linear indexing fixed;
  • SS-3519: German units names translations updated.
Miscellaneous
  • Loading speed of the program increased;
  • Refactoring.
Download
SMathStudioDesktop.0_99_6654.Mono.tar.gz (1.28 MiB) downloaded 1825 time(s).
SMathStudioDesktop.0_99_6654.Setup.msi (2.15 MiB) downloaded 3914 time(s).
6 users liked this post
sergio 3/22/2018 6:29:00 AM, Вячеслав Мезенцев 3/21/2018 11:24:00 PM, NDTM Amarasekera 3/22/2018 12:10:00 AM, frapuano 3/21/2018 6:56:00 PM, IVR 3/22/2018 3:35:00 PM, Василий Николаевич Храмушин 3/23/2018 12:34:00 PM
#2 Posted: 3/26/2018 5:41:04 PM
1,350 likes in 2,262 posts.
The behaviour of loops with second value seems to have improved. Is this generally fixed or just by chance?
Andrey Ivashov 3/28/2018 12:43:00 PM
#3 Posted: 3/27/2018 3:16:09 AM
Martin_B
Martin_B
22 likes in 84 posts.
Discovered following behaviour concerning pagebrakes with very long blocks:
(scroll to right if necessary)
The red marked block is so long, that it reaches the top of following page.
As you can see in the preview window, the sheet content is not printed.
Page 2 starts after the page brake with "Biegedrillknicken" when "Printing Bounds" is used.
While using "Pages view", the first printed page looks the same (mostly white) but the second page starts with the skipped content "System l=5,00m..."
Setting the font size only of the large block to something smaller so the bottom of it doesn't reach the page brake solves this issue.
#4 Posted: 3/27/2018 6:52:36 AM
Martin_B
Martin_B
Found another issue, while editing the description of a 2D plot:
When you put the cursor in the description and edit the text, a matching variable in the input data is edited simultaneously.
Screenshot: description is edited -> a second cursor appears in input data
#5 Posted: 3/27/2018 9:29:54 AM
Not clear w/o the document.
#6 Posted: 3/27/2018 9:36:59 AM
Discovered following behaviour concerning page brakes with very long blocks:
Maybe the problem is the construction ?
Document would surely help volunteers.
#7 Posted: 3/27/2018 9:59:31 AM
Martin_B
Martin_B
Here you are:
Pagebrake.sm (70.7 KiB) downloaded 1528 time(s).
#8 Posted: 3/27/2018 10:39:37 AM
Here you are:
The long page brakes are not in the attachment !
sin(x0 something => no problem Smath 6179
#9 Posted: 3/27/2018 11:16:10 AM
Martin_B
Martin_B
Here you are:
We are here in the "RC2: 0.99.6654"-thread.
So I thought it would be clearly that I refer to 0.99.6654.
Take a look at the video (screen capture) if you don't believe what I am writing.
SMath Studio - [Pagebrake.sm] 27.03.2018 15_58_31.mp4 (2.84 MiB) downloaded 453 time(s).
Here you are:
Sure they are (I uploaded a simplified example):
frapuano 3/27/2018 11:29:00 AM
#10 Posted: 3/27/2018 2:32:10 PM
Your screen shot is explicit enough, but the document would help
more collab to check that particular issue or similar problem.
Nobody reported this bug, if it is an Smath bug.
#11 Posted: 3/27/2018 3:00:06 PM
Martin_B
Martin_B
Found another issue, while editing the description of a 2D plot: ...
The document is linked in post #7. And the screen capture in post #9.
#12 Posted: 3/27/2018 3:22:30 PM
Arie
Arie
94 likes in 285 posts.
Here you are:
Can repeat both bugs with the provided file on 6654. Oddly enough I was able to enter a description sometimes without effecting the data field if I first clicked within the data field, then immediately clicked the description field. This only worked occasionally and seemed dependent on where I clicked within the data field.
frapuano 3/27/2018 5:47:00 PM, Martin_B 3/27/2018 3:53:00 PM
#13 Posted: 3/27/2018 6:32:05 PM
Bug/NObug ... pretty strange, whatever.
The document attached does not contain
the live Smath part in snippet # 3
There is one known shadow in context
You can't define a function starting with 'if'
if(a,b,x):=fnct(a,b,x) ... if NOT allowed.
Quick tip to get rid of "sometimes without effecting the data field"
1. in the description, type few letters not common to data field
2. once finished the description, zap the fake letters.
#14 Posted: 3/28/2018 3:08:09 AM
Martin_B
Martin_B
The document attached does not contain the live Smath part in snippet # 3
To avoid "shadow in the context" I uploaded a very clean sheet (#7) which shows exactly the behaviour I described.
Really don't know why I should want to define 'if' myself.
#15 Posted: 3/28/2018 9:47:11 AM
No bug from [#7], nobody else reported.
can't explain the non-explainable.
#16 Posted: 3/28/2018 12:42:23 PM
Here you are:
Thank you! Both issues are reproduced and will be fixed asap.
Martin_B 3/28/2018 1:39:00 PM, Arie 3/28/2018 2:40:00 PM
#17 Posted: 3/28/2018 12:43:47 PM
Was not my goal. Looks like some refactoring might helped.
#18 Posted: 3/28/2018 1:27:49 PM
It has some interest,
but needs be distinguished by some invention.
#19 Posted: 3/28/2018 3:24:13 PM
Ruben Sidranski
Ruben Sidranski
17 likes in 465 posts.
Are you doing something wrong or bug wrt your Smath version?
My sheet has the app version. I'm on 0.99.6654. Looks like that may be the problem
https://en.smath.info/forum/yaf_postsm47682_X-Y-Plot-Region.aspx#post47680
Jean confirmed similar issue with Maxima plugin too https://en.smath.info/forum/yaf_postsm47682_X-Y-Plot-Region.aspx#post47682
#20 Posted: 3/28/2018 5:46:37 PM
Ruben Sidranski
Ruben Sidranski
"0.99.6661" fixed the x-y plugin problem
