how to apply a conditional to an interval
how to apply a conditional to an interval - Messages
#1 Posted: 1/5/2022 6:03:42 PM
TIAGO C DOS SANTOS
TIAGO C DOS SANTOS
1 likes in 27 posts.
Good afternoon, could someone explain to me how to solve this problem I need that the horizontal voltage varies according to the depth however and the s2 gamma.
my input data is hprofundidade1 z w and y
TESTE TENSAO ADM MATRIZ.sm (5.41 KiB) downloaded 1030 time(s).
#2 Posted: 1/6/2022 1:50:51 AM
598 likes in 1,379 posts.
I didn't understand what to calculate in sigma function.
A little more explanation would help to resolve it.
TESTE TENSAO ADM MATRIZ_r1.sm (8.44 KiB) downloaded 1045 time(s).
Show Spoiler
#3 Posted: 1/6/2022 7:57:04 AM
TIAGO C DOS SANTOS
TIAGO C DOS SANTOS
I don't understand the problem, only to get a plot.
Good morning,
I reworded the file with an SPT matrix, my goal is to loop to find the value of sigma h in the depth that I inform in the input I am attaching a photo of what the final result should look like with the graph
TESTE TENSAO ADM MATRIZ.sm (13.15 KiB) downloaded 1036 time(s).
#4 Posted: 1/6/2022 3:04:40 PM
1,118 likes in 1,794 posts.
Hi. I think that this could be the solution.
TESTE TENSAO ADM MATRIZ.sm (5.88 KiB) downloaded 1029 time(s).
#5 Posted: 1/6/2022 4:49:36 PM
I still don't understand purpose of for() loops. (not in your solution, original question)
Removing for()'s and calculating directly won't change the result.
#6 Posted: 1/6/2022 7:06:33 PM
Hi overlord. I guess because using γ.s2(h)*h isn't correct, there the correct acumulation is γ.s2(h)*Δh
TESTE TENSAO ADM MATRIZ.sm (10.8 KiB) downloaded 1007 time(s).
#7 Posted: 1/7/2022 8:51:39 AM
TIAGO C DOS SANTOS
TIAGO C DOS SANTOS
Good morning,
thank you all for making your time available, helping me with this problem but some of the solutions posted here do not match the values must be equal to sigma,v in the image or 70 kN/m2 at 4m depth and 118 kN/m2 at 7m depth.
see the resolution of the problem in the attached image
#8 Posted: 1/7/2022 11:23:15 AM
TIAGO C DOS SANTOS
TIAGO C DOS SANTOS
At this point, up to You to handle the project.
I understood nothing in that big image.
TESTE TENSAO ADM MATRIZ (in_situ parametric).sm (18.6 KiB) downloaded 1084 time(s).
PERFECT FELL LIKE A GLOVE is there a way to rotate the result of the graph 90 degrees?
#9 Posted: 1/7/2022 4:01:35 PM
...some of the solutions posted here do not match the values must be equal to sigma,v in the image or 70 kN/m2 at 4m depth and 118 kN/m2 at 7m depth.
Hi. You can try to change the input values by yourself.
#10 Posted: 1/7/2022 5:44:30 PM
This is a way to do that in SMath.
TESTE TENSAO ADM MATRIZ v2.sm (455.7 KiB) downloaded 1131 time(s).
#11 Posted: 1/8/2022 11:14:01 AM
... updated from Alvaro latest addition.
Cleaned image(s) for publishing the traced reference.
You can have as many sets of parameters [p,d] as you wish,
even of different length as long as you update respectively.
Project Algo_Parameters.sm (661.95 KiB) downloaded 1053 time(s).
I guess the last 4 'x' points [18,19,20,21] should be removed.
#12 Posted: 1/8/2022 2:36:52 PM
Razonar's post has answer already. Jean's post is a re-post.
No reason to re-post same file with some enigmatic, non-related, preceded functions.
TESTE TENSAO ADM MATRIZ v2.sm (455.7 KiB) downloaded 1131 time(s). <--- Razonar's post
Project Algo_Parameters.sm (661.95 KiB) downloaded 1053 time(s). <--- Jean's shameless repost (don't download this)
#13 Posted: 1/8/2022 4:45:12 PM
Offered as demanded in two separate parts in same document.
Thank you all for making your time available, helping me with this problem but some of the solutions posted here do not match the values must be equal to sigma,v in the image or 70 kN/m2 at 4m depth and 118 kN/m2 at 7m depth.
Project Algo_Parameters Copy.sm (663.42 KiB) downloaded 1044 time(s).
#14 Posted: 1/8/2022 6:28:58 PM
I am pretty sure topic owner didn't request from someone to re-post one anothers sample.
Alvaro 1/8/2022 8:58:00 PM, fedeghi 1/9/2022 7:57:00 AM
